Connectors for a 16.8V pack 10A
Ozzyfr   10 µW
10 µW
Post by Ozzyfr » Jun 18 2018 1:11pm
Hi, I am building a pack 4S9P and I would like to use a GX connector,
I saw GX12 connectors that can handle 5A at 220V or GX16 7A at 220V
Would a single pin of a GX 12 could handle 10A at 16V ? I guess yes if P=U.I then a single pin would support just 1/10 of its maximum at 10A and 16V right?
or should I use 4 pins of a GX12 and connect the + and - to 2 pins each to divide the amps going through each
or should I use a GX16 ?
Thanks!
jonyjoe303   1 W
Re: Connectors for a 16.8V pack 10A
Post by jonyjoe303 » Jun 18 2018 1:49pm
I would say no, the pins where the wires are solder are extremely small, for small gauge wire. I use those connectors before and I wouldnt run any large amps (at low voltage) through them, maybe 5 amps.
Even though small gauge wire can handle 10 amps at (low voltage) they will get quite warm.
What kind of gauge wire were you planning on using? those connectors will be about 18 gauge to solder properly.
flippy   10 kW
Post by flippy » Jun 18 2018 3:36pm
Why not use some XT60?
Lithium beats liquid dinosaurs.
Ozzyfr   10 µW
10 µW
Post by Ozzyfr » Jun 20 2018 4:31am
I like the GX series as they are securely screwed, I was planning on using 12 or 14AWG
flippy   10 kW
Post by flippy » Jun 20 2018 6:34am
you can but they will melt, especially the fake ones you get from china.
5A limit is 5A limit. it does not matter what the voltage is.
also if you are going that route you need to use all the pins so double or triple up.
spinningmagnets   100 GW
Post by spinningmagnets » Jun 20 2018 7:01am
The main design consideration that voltage imposes on component design is that...the higher the voltage, the farther a spark can "jump" from one connector to the other. This is why computer chips typically use only 5V (with a lot of tiny and thin conductors squeezed together very closely), and 220V connectors have pins that are farther apart than 110V connectors. You could run lower voltages on connectors designed for higher voltages, but you should never go the other way.
When it comes to amps, you need a larger cross-section of conductor (fatter wire) when the amps are higher. You could run lower amps on fatter wire, but...if you run high amps in skinny wire, it will get too hot, along with the system experiencing a voltage drop due to the wire being too small to handle the desired amps.
Ozzyfr   10 µW
10 µW
Post by Ozzyfr » Jun 20 2018 7:35am
That’s clear thank you!
So what about dividing the connection across 2 pins of a 4 pins gx12 or a gx16? Would a max of 10A be divided in 2 so 5A max on each?
flippy   10 kW
Post by flippy » Jun 20 2018 9:20am
it depends on the manufacuters rating of the connector.
some have a per pin current rating and others have a combined rating, yo see this a lot in the "oriental markets" to boost their ratings.
i think 10A sustained in that cheap 4 pin connector is pushing it. it will get hot and in due time it will melt.
try using something like this: https://www.aliexpress.com/item/WEIPU-W ... 82457.html
i use these connectors for a lot of setups. the panel side has a spring loaded cover so crap can never get in and you cant forget to close it.
it also has no problem with 15A sustained.
Ozzyfr   10 µW
10 µW
Post by Ozzyfr » Jun 20 2018 12:20pm
Thank you for the link,
These seam a bit oversized for what I need to do, I will not draw 10A continuously, only for a few seconds then it should not be more than 5 or 6A Do you know something that is between the gx12 and the wp20?
flippy   10 kW
Post by flippy » Jun 20 2018 1:54pm
what are you going to use it for? charging or running a motor or something?
might want to check here: https://www.aliexpress.com/store/produc ... 39263.html
1 size down but if you say 10A "for a few seconds" you are really saying that you need 10A continous. if you are already running at the limit at 5A and then you do a 10A burst you will melt the connector. ALWAYS assume worst case. i got 5 jobs the past month rebuilding batteries and 4 of them had melted connectors.
