The good news is that I just receive them today! Straight from Hong Kong!
And the other good news is that YOU can help me out with the wires issue.
Let me show you...
First of all, I have a Ezee motor hub kit with a Ezee controller. The Ezee controller has typical Anderson power connector. I use a “ductapped†48v/8Ah NiCAD pack as below:
The pack have 2 connectors; 1 Anderson connector to draw power from the pack
And a XLR for recharging
Now, here is the LiFePO4 48v/20Ah from M. Xie:
The pack has only a 3-pin connector.
The kit include a XLR plug
And a cable interface from 3-pin connector to XLR connector
This cable interface let me connect the LiFePO4 pack into the charger
Ok.. My first question is: “Can I build an interface cable from 3-pin connector to Anderson power connector to connect the LiFePO4 into Ezee controller?â€Â
My second question is: “The LiFePO4 only have 1 wire.. if I understand, I can draw power from the pack AND recharge the pack from the same cable?†Hey! stop laughing..
Thanks guys,
