Upgrading a DPV Battery
underpendle@yahoo.com   1 mW
Post by underpendle@yahoo.com » Jun 30 2019 3:14pm
Hi Guys, thanks for the add.
Im hoping for some advice on a project Im doing. I want to upgrade the duration of the battery on my Dive Scooter for a long cave project Im on. At present it is powered by Li Ion cells running at 25.2V 512Whr. If Ive done the sums right then 7S13P, built with 3400mA cells will give me a shade over 1750 Whrs. Or in other words slightly more than 3 times the duration.
This I think will work in terms of physically fitting it in the unit without adding any significant mass. 4550g total. At present 4160g This is further complicated because an under water vehicle is reliant on being neutrally buoyant. I think the 500g increase in mass will be offset by a slight reduction in volume. I can also remove/add a small amount of ballast if need be.
Ive allowed a small volume for a BMS.
This will obviously need field testing and Im hopeful that I may actually end up positively buoyant and could therefore add further cells.
Ive been looking at Panasonic cells, which I will spot weld together using Ni strips.
Do Any of you experts see any obvious flaws before I spend a lump on cells?
Any advice gratefully received.
Cheers
Simon H (UK)
999zip999   100 GW
Re: Upgrading a DPV Battery
Post by 999zip999 » Jun 30 2019 5:01pm
13p great I slit would use high quality cells. And gaskets on pos side. Make sure all cells are of same voltage and batch before assemble. Lots of threads on blue tooth BMS.
Post by underpendle@yahoo.com » Jul 01 2019 12:01am
Thanks, when you say gaskets do you mean the small cardboard disks? Such as https://www.ebay.co.uk/itm/200x-18650-B ... 2965161639
Cheers
999zip999   100 GW
Post by 999zip999 » Jul 01 2019 10:22am
Yes as some manufacturers use a palstic separater and can melt. Plus the whole can is neg.
Post by underpendle@yahoo.com » Jul 01 2019 1:07pm
Again thanks.
Im about to order my cells.
Panasonic NCR 3400mAh/6A Rechargeable Flat Top 18650 Battery
Are these considered a reasonable cell?
If you don't mind me asking does my math add up?
7s13P
7x3.6= 25.2 Nominal V
13x3400= 44200mAh
44200/25.2=1754Whr
Simon
999zip999   100 GW
Post by 999zip999 » Jul 01 2019 3:01pm
what exact cell are you talking about who you buying yourselves from ? Nikon ? I think that's where most of the people in Europe buy them from new cells
Post by underpendle@yahoo.com » Jul 01 2019 3:54pm
Thats a panasonic NCR18650B, they seem to review ok here? from techdelivered.co.uk £10 a pair.
TBH Im not well up on this tech only really started researching because of this project, from what I have gathered, stay away from chinese stuff and recycled, This is a critical piece of equipment so not going to skimp for a few quid . Am finding it interesting though. Every days a school day
S
Post by underpendle@yahoo.com » Jul 01 2019 3:58pm
Just looked on Nkon bit better price there, thanks :bigthumb:
LuboN   100 mW
Post by LuboN » Jul 10 2019 3:27am
Wh is calculated Ah x Voltage. Real life Ah would be little lower value, let us say 3,3Ah. 3,3x13=42,9Ah x 25,2V = 1081Wh. How much current does it consume during dive or what is the wattage of the motor? This is important before making cell choice.
