New 52v battery sat unused for two years...
Stu Summer   10 W
Post by Stu Summer » Jul 11 2019 9:23pm
I see on Craigslist a Luna triangle battery 52v, 28ah, GA. It is unused, bought in 2017, still with wrappings on the plugs. How much capacity will it have lost? They are asking $600 for it ($1000 new). Thanks.
2013 DB Haanjo Commuter with BBSHD and Zzipper fairing
Marin Rift Zone FS with BBSHD
Kysmo "lab" bike with 350w hub motor
Ryan Vanguard recumbent LWB with a 36v Cyclone 350w middrive and a 56v MAC 5t in the front hub.
amberwolf   100 GW
Re: New 52v battery sat unused for two years...
Post by amberwolf » Jul 11 2019 10:28pm
if they haven't kept it charged the bms probably drained it dead and destroyed it.
flat tire   1 MW
Post by flat tire » Jul 11 2019 10:39pm
There are lots of GOOD battery options out there, I wouldn't touch that.
Drunkskunk   100 GW
Post by Drunkskunk » Jul 12 2019 1:14am
If it sat in the heat of a garage, it might have been baked to death. Lithium degrades in the heat.
I would avoid. Batteries have a limited shelf life anyway.
LeftieBiker   10 kW
Post by LeftieBiker » Jul 12 2019 1:22am
The only way that battery could possibly be ok would be if the BMS was disconnected at the factory and had to be connected by the purchaser. Ping Packs came that way.
john61ct   1 MW
Post by john61ct » Jul 12 2019 1:26am
Might be worth testing, if V over 2.5V offer $100
Stu Summer   10 W
Post by Stu Summer » Jul 12 2019 2:28pm
Thanks everyone! Very clear.
Matador   10 kW
Post by Matador » Jul 13 2019 8:27am
Could be perfectly Okay... A 28Ah battery is massive and can take a decade to drain from BMS if the pack was stored full...
But if it was stored near 0%, then some of the cells could be toast.
Assuming the cells were NMC, never used, and stored at 50% and a in a garage at ambient temperature of 25°C, the cell should have a remaining usable capacity of above 95% and a DCIR no more than 110% that of brand new. But that's before considering BMS parasitic current draw.... Wich is typically in the uA (microamps) range...
If overall the battery still sits at a voltage anything higher than 50V, i would buy it for a best offer of 400$. 300$ would be more reasonable. Then I would manually balance each cell string as the BMS drain is normally uneven, ofter targeting the first 3 parralleled cell groups...
But if I assume the BMS has a 50uA drain and the guy did not lie about the 2 years duration, then
50 uA = 0.05 mA = 0.00005 A (of BMS draw)
So in 1 hour, thats 0.00005 Ah drained out of 28Ah
So in 1 day, thats 0.0012 Ah
So in 1 year, thats 0.436 Ah
So in Two years, thats about 0.9Ah ...
So in 2 years, such BMS would drain 0.9Ah out of 28Ah. Meaning in two years it would drain about 3.5% of the capacity of that huge battery.....
So unless it was stored empty from the start, I'm quite confident the battery cells are still good.... But look up the specs of the BMS in that pack to be sure about the current it draws... Also, make sure the pack is made of good, brand name 18650 cells... Finally check to see how many cycles (from story, i would assume zero cycles) the pack has.... Also was it stored at 25 or 40 degree celcius ????
Matador
Matador   10 kW
Post by Matador » Jul 13 2019 8:32am
Another name for this BMs spec figure is "BMS Quiescent current draw"... This figure should be on any respectable BMS datasheet.
Matador
Volt_Ampere   10 W
Post by Volt_Ampere » Jul 13 2019 10:44am
Me - I would not risk it. It might be ok but no way would I pay $600 for it.
LeftieBiker   10 kW
Post by LeftieBiker » Jul 14 2019 12:12am
Nice BMS if you can get it! They do have a habit of drawing more than that, though - a lot more. I have two 20AH Ping packs. The earlier, hand-built by Ping himself, pack does have a very low vampire drain. The later one, though, draws about 10X that much, by my estimate. It's better to assume the worst but hope for the best than the other way around...
john61ct   1 MW
Post by john61ct » Jul 14 2019 9:35am
This is why I would only buy packs where the BMS can easily be disconnected, bypassed or replaced.
Stu Summer   10 W
Post by Stu Summer » Jul 16 2019 1:42pm
Thanks everyone for you cautions. I let it go!
