0-120V 0-30A variable rectifier/amps/charger, is it ok?
Darren2018   100 W
Post by Darren2018 » Jul 27 2019 5:49pm
Does anyone have any information or a review on this charger? https://www.aliexpress.com/item/32999030765.html
These chargers are not too expensive but the modules that are not yet modded seem really cheap. I wonder how difficult it is to modify one to make one of these variable chargers?
I think this might be the supply needed? https://www.aliexpress.com/item/32852992503.html
They are incredibly compact for the power and size.
Darren2018   100 W
Re: 0-120V 0-30A variable rectifier/smps/charger, is it ok?
Post by Darren2018 » Jul 30 2019 10:59am
Does anyone have any information regarding these?
flippy   10 MW
Post by flippy » Jul 31 2019 9:07am
they are secondhand hacked server power supplies usually meant for telecom towers.
Lithium beats liquid dinosaurs.
leffex   1 kW
Post by leffex » Jul 31 2019 1:58pm
Yes its awesome and works perfectly
:banana: :banana: :banana: :banana: :banana: 5/5
Salestech in an ebike store
Darren2018   100 W
Post by Darren2018 » Jul 31 2019 3:32pm
flippy wrote:
Jul 31 2019 9:07am
Do you know how to make one?
Darren2018   100 W
Post by Darren2018 » Jul 31 2019 3:34pm
leffex wrote:
Jul 31 2019 1:58pm
Have you got one of these Leffex? If you do what voltages and currents have you tried? Is the output stable and reliable?
Drunkskunk   100 GW
Post by Drunkskunk » Jul 31 2019 4:05pm
220 input voltage make's it limited use to me. Not may common plugs in the U.S. are 220.
it does look like a hack job of a blade style server power supply. That PCB blade under the plugs would normally be, and may still be live power. Be extra damn careful handling it.
But a hacked power supply may still be a good bulk charger, and the price might be fair considering time and effort. 10 years ago, I built my 100v 5A CCCV bulk charger out of a couple $100 Meanwell power supplies I hacked. whole thing cost me $250 in the end, and was only 5 amps. It might be worth someone's time and money to start with something like this.
leffex   1 kW
Re: 0-120V 0-30A variable rectifier/amps/charger, is it ok?
Post by leffex » Jul 31 2019 5:50pm
Yes true. Charging only under on-sight as well. I use a 88v charger changed to about 90,5v. and about 5a
The charger looks like this:
https://www.aliexpress.com/item/3299426 ... b201603_52
leffex   1 kW
Post by leffex » Jul 31 2019 6:00pm
The charger is based on R4850G
R4850G looks about like this inside:
viewtopic.php?t=86038
leffex   1 kW
Post by leffex » Jul 31 2019 6:04pm
Darren2018 wrote:
Jul 31 2019 3:34pm
leffex wrote:
Jul 31 2019 1:58pm
I have tried it at maximum about 92,5v charging at 20-25A. So I guess the maximum is either only specified as "Amps" (0-90, max 30A and 0-120v max 25A i.e. 3000w max) and not the voltage really but I don't want to experiment and I will not use so much higher than 90v anyway.
Darren2018   100 W
Post by Darren2018 » Jul 31 2019 8:45pm
leffex wrote:
Jul 31 2019 6:04pm
Darren2018 wrote:
Jul 31 2019 3:34pm
leffex wrote:
Jul 31 2019 1:58pm
Thanks Leffex there was a quite a lot of information on that thread. Good to hear you have had success at the full voltage. Have you tested the efficiency? How hot does it get at 25A?
amberwolf   100 GW
Post by amberwolf » Jul 31 2019 8:52pm
Drunkskunk wrote:
Jul 31 2019 4:05pm
Usually dryer and stove/oven are 220v, 30-50A. The kitchen outlet is not usually convenient to get to and plug/unplug, or make a splitter for, but the dryer outlet often is.
Unfortunately if you need to make your own cord from scratch the plugs are expensive ($30-60) new, but if you don't mind looking at thrift stores over several weeks to months, you can find a whole cord and plug for a few dollars.
leffex   1 kW
Post by leffex » Aug 01 2019 1:36pm
Darren2018 wrote:
Jul 31 2019 8:45pm
leffex wrote:
Jul 31 2019 6:04pm
Darren2018 wrote:
Jul 31 2019 3:34pm
leffex wrote:
Jul 31 2019 1:58pm
Hot to touch. You can hold it if you want. So not that hot. That means you are pushing 25A at least. It starts heat up in about 20 minutes after start but it has a fan that's sets in taking care of it.
szczur333   10 µW
10 µW
Post by szczur333 » Sep 30 2020 9:39pm
sorry for resurecting old thread but I am wondering WHY they stop selling these moded PSUs, without mod they are avaible about 100-120$, sometimes locally i saw them for equvialent of 70-80$ - O_o
I can easy find 0-20A models but 30A is almost impossbile or a lot more expensive
I found two sellers 0-30A (little diffrent shape) but after i bought it they said 0-20A models are avaible they will not sell 30A models anymore
anyone has an idea how to mod that rectifier for higher voltage>?
flippy   10 MW
Post by flippy » Oct 01 2020 5:02am
the reason you dont find them any is because they blow up.
too small a package with shitty chinesium parts that need to work oustide optimal range means you blow the arse out of them in a few months.
if you need a changer for a certain battery you need to get a charger that is optimized for that voltage and current.
these are fairy good if you still want a wide range: https://www.aliexpress.com/store/group/ ... 03805.html
use this formula fo you go below the optimal voltage: if you have a 50% reduction in voltage also do a 50% reduction in current.
also: take it apart and make pictures of ALL the parts, especially the mosfets and diodes. once they blow up you cant read the part number anymore so having a picture before it blew up makes replacing parts simpler.
