flippy said:
docware said:
If you use new, appropriate original cells from Big Four, actual need for balancing current is zero. Assuming you are not abusing them (high discharge current, high DOD, …..).
So the need is not zero.
I have strong notion that balancing of the cell groups is often overemphasized regarding the lifetime of the battery pack. Yet there are factors like DOD, charge rate, discharge rate, SOC, optimal temperature, etc, which are most significant for Li-ion cell degradation. Effort to save the battery pack after abusing the pack by running it high DOD, charge rate, discharge rate, …., seems to me somewhat – ineffective.
I am not saying that BMS is needless, I am saying that we should concentrate on the beforementioned factors and optimize battery pack to the optimal parameters if lifetime of the battery pack is our priority. No SMART BMS can improve battery pack lifetime abused by high DOD, discharge rate,…..
If we run the original brand-name cells in the optimal parameters window, balancing by BMS is secondary, or needles.
I first met questioning the BMS role in November 2017 at the Shawn McCarty video :
https://www.youtube.com/watch?v=pljSZcEwc8Q
That awaked my curiosity what is going on in my 10s5p Sanyo GA battery. Ended by wiring each cell group with help of 2pcs of HIGO-B6-B external cables .
After some time found out that Junsi CellLog8 and iSTD Battery Checker BC- 8s are showing different values. In the effort to determine real true values I build single purpose equipment. In fact it is battery powered simple voltmeter with 0,1 mV resolution and a rotary switch and possibility to connect external voltmeter. By the way, Junsi CellLog 8 itself can have inaccuracy up to 10 mV.
In the equipment is built-in also precise voltage reference MAX6341 (4,096 V ±0.02%) at the rotary switch position No 6.
The main advantage is differential measuring of the cell groups by one voltmeter and sufficient resolution 0,1 mV.
From the very beginning of the measurement in May 2018, the cell groups were usually in the range 3 mV. At the same time I started to charge to cca 4 – 4,1 V max, so that the battery BMS didn´t enter into balancing mode probably more than 14 months now, at least.
Need to say that DOD, charge rate, discharge rate, SOC, … are very friendly for this 10s5p Sanyo GA battery.
Here are measuring results from 2019 :
Such stable equal voltage is reason for my doubt of BMS balancing importance.
