Odessadream
- Joined
- Sep 27, 2018
- Messages
- 12
I make every day short trips of about 10 km. When I return home the batery indicator has still 5 out of 5 stripes, Nevertheless I connect the battery to the charger untill the red indicator on the charger switches from red to green and than I disconnect the charger immediately. Once every 2 weeks I charge the battery when only 2 out of 5 battery indicator stripes are visible and than recharge the battery. I now notice that when i have a full battery after disconnecting the charger and leaving the battery over night from the battery, connect the battery to the charger the red indicator of the charger lights up for about 15 minutes. So the battery decharged overnight a little which not happened when the battery was new. With this battery I drove 1100 km so the battery fairly new. My question is :
1. What is the correct procedure in terms of life time to charge the battery ?
2. Is my battery already failing more than it should after driving 1100 kn with it using my charging procedure ?
