can the tesla battery module be charged with a hobby charger is there anything about the chemistry of the 18650 cells they use any different that would require a proprietary charging system?
i know the stock oem bms may be proprietary and may not work so it would have to be replaced with either a bms or balance leads so it can be charged.
i know if you use the modules in a power wall you will need specific charging systems but for ebike use i dont know
the video that mentions about it is
https://www.youtube.com/watch?v=rRYWT-8LWrw&t=1s
thanks
thanks
