Jan-Erik-86
- Joined
- Jan 23, 2019
- Messages
- 110
My 14s pack was put together, BMS connected, and ready to go for wrapping.
This is when i decided i should use some more hot glue on the balance wires before wrapping to prevent any rubbing over time and risk a short. This is the BMS type I'm using: https://www.ebay.com/itm/BMS-PCB-PCM-for-50-4V-14S-Li-Ion-Battery-Pack-45A-Drain-Rate-w-Balance-Function/172971369981
All went fine with the + leads for all 14 cells, but what i didn't know was that my hot glue was now warmer then the melting point of the wire insulation. This lead to a short between the GND balance wire and the final + terminal.
The wire section vaporized in a flash, and i was sure the BMS would be dead at this point - after having received +50V to the GND balance lead.
Much to my surprise, it appeared the BMS was still functional. There was only a connection between C- and B- when the balance leads were connected, indication it must have detected 2,8-4.2v on all balance leads.
Now here's where i did my big mistake...
While i checked that it would both take charge and discharge without issues, i completely forgot to check the balance and overcharge function of the BMS before i wrapped it in, put it in the battery box, and glued it shut...
At this point i have no way to check the actual cell voltage without literally cutting the box open.
Do you guys think it's likely that the balance and/or overcharge protection could still have been damaged from this, even though the BMS appears to work fine?
