Charging and Balancing Questions for LG HG2 pack (14S/20P)
garolittle   1 kW
Post by garolittle » Oct 18 2019 1:05pm
Hello. I am using a 14S/20P pack of LG HG2 cells (“18650 lithium ion”) for my prototype electric go kart.
What is a safe charging rate for a 20P configuration? I typically charge at 15-20 amps (CCCV)
What is a normal “Minimum Voltage per cell”. I have an Orion JR. BMS that is set for 2.9V minimum but I am wondering if that is too conservative. The spec sheet for the LG HG2 shows 2.5V as the minimum but I do not want to go that low for a variety of reasons.
What is typical “safe difference” in cell voltages after discharge? I pull approximately 100 Amps (continuous) and 350 Amps (maximum “bursts”) on my electric go kart and usually have about .03V to .05V difference between the highest and lowest cells. Is this a good range?
Thanks for any responses or suggestions.
Gary
VenomKarts, LLC
VenomKarts.com
Augusta, GA
pwd   100 W
Re: Charging and Balancing Questions for LG HG2 pack (14S/20P)
Post by pwd » Oct 18 2019 1:41pm
Hi Gary,
The standard rated charge current is 1500mA per cell, so 15-20 amps for 20P seems safe. I would leave it at that.
The minimum cell voltage of 2.9V isn't conservative enough for my taste. I would say around 3.0V - 3.1V per cell for the BMS and 3.2V - 3.3V per cell or 44.8V total pack voltage for the controller's low voltage cutoff. You will get more cycles this way and avoid over discharging under load.
You haven't mentioned it but if you also charge to a max of 4.05 to 4.1V per cell, that will also net you more cycles.
A cell string voltage difference of .03V to .05V seems high. I would shoot for 0.01V difference or less.
Good luck with the build.
Commuter/Street Build:
Rocky Mountain Element
Magic Pie 4 front + Leafmotor 1500 rear w/ WCEC 18fet
em3ev 14S5P 30Q + 14S6P 25R pack
Build Thread: viewtopic.php?f=6&t=98286
Offroad Build:
2019 Rocky Mountain Blizzard 20
Cyclone "3kw" 13T motor to 44T chain ring then 36T chain ring to 11T-46T Cassette
em3ev 14S5P 30Q
garolittle   1 kW
Post by garolittle » Oct 18 2019 2:12pm
pwd wrote:
Oct 18 2019 1:41pm
Thanks for the response. I typically charge to a maximum of about 4.07V Per cell so I it sounds like I’m OK in that regard. After balancing, the cell variance can reach about .01V. It can be higher after a long day of testing and tuning but it seems to balance out nicely. I really do appreciate your feedback. Thanks again. Gary
VenomKarts, LLC
VenomKarts.com
Augusta, GA
john61ct   10 MW
Post by john61ct » Oct 18 2019 9:19pm
cell variance at .01V should be the trigger for balancing to start.
20-30mV should be where they end up.
LVC really should be higher if at all possible for longevity,
voltage sag depends on your peak loads
should end up no lower than 3.4Vpc after resting bounceback.
garolittle   1 kW
Post by garolittle » Oct 19 2019 1:58pm
john61ct wrote:
Oct 18 2019 9:19pm
Thanks Sir. Really appreciate the response.
VenomKarts, LLC
VenomKarts.com
Augusta, GA
garolittle   1 kW
Post by garolittle » Oct 21 2019 5:40pm
pwd wrote:
Oct 18 2019 1:41pm
I know it is not a perfect analogy, but Tesla recommends keeping the State of Charge between 20% and 80% on their vehicles. Would the recommendation above be similar to these percentages? Thanks.
VenomKarts, LLC
VenomKarts.com
Augusta, GA
john61ct   10 MW
Post by john61ct » Oct 21 2019 7:34pm
garolittle wrote:
pwd wrote:
Oct 18 2019 1:41pm
That was just the low end, not top.
But no, there is very little usable energy left below even 3.4Vpc at rest for those chemistries.
80% DoD as a normal stopping point does greatly extend life, but often just is not practical to pull over and sleep there.
For stop-charge, just 1.0-1.5V below the max spec is plenty conservative, and again sacrifices insignificant range in practice. Would be silly to stop any lower.
Charging at a lower current has a great impact on longevity, as would gentle driving patterns.
garolittle   1 kW
Post by garolittle » Oct 21 2019 7:38pm
Thank you. I really do appreciate the response. Gary.
VenomKarts, LLC
VenomKarts.com
Augusta, GA
garolittle   1 kW
Post by garolittle » Oct 22 2019 12:05pm
Thanks again for all of the great responses. Would higher numbers of cells in Parallel make lower voltage strings acceptable? For example, if I used 14S/30P instead of 14S/20P, would this allow for lower voltages per cell string? Just curious. Thanks. Gary
VenomKarts, LLC
VenomKarts.com
Augusta, GA
john61ct   10 MW
Post by john61ct » Oct 22 2019 1:52pm
No, really separate parameters.
Ah capacity will help support amps discharge rate, lower stress on the cells, and of course range.
The loads - in this case motor + controller - will determine what voltage you want, taking desired top speed into account.
But going faster drastically lowers range.
So if you had an adequate but fixed number of cells, balancing top speed vs range would be your judgment call.
garolittle   1 kW
Post by garolittle » Oct 22 2019 7:15pm
john61ct wrote:
Oct 22 2019 1:52pm
Excellent information. Thanks Sir!
VenomKarts, LLC
VenomKarts.com
Augusta, GA
