I am looking for some suggestions for re-use of LiIon cells. I am rebuilding my Bafang Pack after an over discharge incident with new cells.
The old cells I will make a "spare" battery.
When dismounting the pack even though I used care I wound up with some small nicks and cuts on the protective sleeve of the battery. My cutting pliers were not good quality.
The cuts near the positive end seem to now make a higher risk of short when rebuilding a new pack.
I am rebuilding with plastic snap together battery connectors so the risk of direct contact is lower.
I have some paper washer stickers.
I am still concerned.
Is there any suggestions for a paint/glue or something that can be used to fix small cuts and tears, what do you do when you see there is a risk of short circuit??
