Electrolyte leak?
BDamari   10 W
Electrolyte leak?
Post by BDamari » Sep 23 2020 5:06am
I was salvaging cells and noticed corrosion/rust looking bumps creeping under the insulation.
Obviously I won't be using those cells in my projects, but are these ticking time bombs or just garbage?
https://imgur.com/a/rREF8kI
kdog   10 kW
Re: Electrolyte leak?
Post by kdog » Sep 25 2020 6:09am
Most likely stable if flat, but obviously don't charge or try to use them. Chuck them in a battery recycle facility near you. If they have charge then they could be an issue if severely rusted (like though the case) and then subject to an impact, or if they are charged. Then you have a fire risk. Discharge them in a fire proof container /place and then recycle as above.
Edit spelling.
999zip999   100 GW
Post by 999zip999 » Sep 25 2020 3:53pm
What type of cell how much voltage is in them ? If there's a charge in them they can make fire even in the recycling bin you could put a tail light from a car on there or a headlight in drain them. Or put them in a bucket of water.then salt and that will kill it . But your water will bubble green with brown form on top . This was Harold out but then I think that water is toxic.funny thing is when you put it in the water nothing happens will you put the quarter cup of salt in their things happen fast. Careful. As they are alive.
Again what type and how big ?
Who I saw the photo 2.5v is zero I think.
BDamari   10 W
Post by BDamari » Sep 26 2020 6:11am
999zip999 wrote:
Sep 25 2020 3:53pm
They're samsung 26f 18650s
