kocetoMR 10 W
Post
by kocetoMR » Oct 16 2020 1:23pm
- spot welder
- 20201016_210956.jpg (482.52 KiB) Viewed 235 times
one side is good ,other side is poor.
Spot welder is from 2P2S supercap 2.8V.Check the cable and connection,they are good.
What can be the problem?
kocetoMR 10 W
Post
by kocetoMR » Oct 16 2020 1:29pm
- capacitors
- 1602872910529.jpg (93.5 KiB) Viewed 233 times
kdog 10 kW
Post
by kdog » Oct 16 2020 5:38pm
Minor variation in electrode pressure or electrode tip shape would be my main guess in that order. My spotwelder is AC so I'm not sure about DC, but welders pay attention to polarity of their workpiece, try swapping tip polarity and see if it reverses. Can't think of anything else ottomh.
kdog 10 kW
Post
by kdog » Oct 16 2020 5:41pm
Have you tried actually spotwelding some nickel?looks like you're just hitting the can there.
kocetoMR 10 W
Post
by kocetoMR » Oct 17 2020 9:27am
- every time when start weld needle neet luke like this
- 20201017_172343.jpg (215.16 KiB) Viewed 184 times
spinningmagnets 100 GW
Post
by spinningmagnets » Oct 17 2020 11:53am
Get some old bad cells, even disposable D cells will work. Use some nickel scrap and weld onto the scrap batteries. The longer path will add more resistance.
Nickel bus, and nickel-plated steel are very good for the parallel connections. For the series, I like the nickel-sandwich method.
viewtopic.php?f=14&t=108006
kocetoMR 10 W
Post
by kocetoMR » Oct 17 2020 1:48pm
- cooper strip
- 20201017_213659.jpg (475.22 KiB) Viewed 166 times
i use sandwich method in many battery pack.In my country copper is with high %gold and is difficult to weld direct to cell with sandwich method.
