Mistory cells?
Mistory cells?
Hey guys and gals I picked up these cells from battery hookup a few weeks ago and they said they were from a Honda insight they are 18s modules each cell is at 3.65v so my guess is 4.2v max charge voltage
And they said that they are Panasonic but I can't find any identification markers on them and they said they were most likely 5 amp hour 60 C but that's not a definite and the problem is Honda doesn't use these flat cells that uses cylindrical ones the closest thing I can find to these is what Toyota uses but those have a green case on them and I think a little bit larger and physical diameter so if anybody has actual first hand knowledge on these or a link to a website with the specs for them that would be much appreciated.
I'm not sure if I can post pictures yet so here is a link to the batteries I bought
https://batteryhookup.com/products/18x- ... -352wh[url][/url]
Edit. From what i have found these are panasonic proto EV cells made for a couple of different vehicle manufacturers such as Honda and Volkswagen
And supposed to be are better than the small C-Max cells. They're supposed to have a higher C rating and handle abuse a lot better then the C-Max 5.5ah cells and they are newer being in use from 2018 to next yr
- Attachments
- 20201105_185959_HDR_copy_480x239.jpg (45.25 KiB) Viewed 181 times
- 20201105_005134_copy_480x960.jpg (135.11 KiB) Viewed 181 times
- 20201105_005152_copy_480x960.jpg (130.96 KiB) Viewed 181 times
- 20201105_005243_copy_640x319.jpg (48.56 KiB) Viewed 181 times
Re: Mistory cells?
Do you have any specific questions?
Re: Mistory cells?
I think i figured out how to post pictures. My question is does anybody know for sure what type of cells days are and if so what the specs for each individual cell is? Because it's all I have are assumptions and guesses but no actual hard facts as to the ratings on these cells
Edit. Well I thought I figured out how to post pictures but apparently I was wrong because I don't see them I will continue to figure this crap out sorry for the delay
Re: Mistory cells?
Adding photos, try this:
viewtopic.php?f=1&t=14748&start=175
Re: Mistory cells?
This is so freaking annoying the largest file you can upload is 512 megabytes and the smallest picture I have is 3.5gig so I'm not sure when the computer software was written for this website possibly 1981? Because I don't know of any modern day picture that's only 512 megabytes smh.....
- LeftieBiker 100 kW
Re: Mistory cells?
Upload them to a site like Imgur and then just link them here with the "insert image" tag in the edit options.
2018 Nissan Leaf SL with Pro Pilot
2009 Vectrix VX-1 Maxi Scooter W/ 18 Leaf modules
2018 Magnum Metro with noisy motor
2019 GreenBike folder
2019 3 wheel 36 volt scooter
Re: Mistory cells?
Looks like you're the one who's out of date, of you can't even resize one of your own photos.Thor230 wrote: ↑Nov 18 2020 2:47amThis is so freaking annoying the largest file you can upload is 512 megabytes and the smallest picture I have is 3.5gig so I'm not sure when the computer software was written for this website possibly 1981? Because I don't know of any modern day picture that's only 512 megabytes smh.....
___________
Finish Reconstruction.
Re: Mistory cells?
Yes it is completely computer 101-level stuff to reduce the resolution of huge pics in order to send them over the internet, my 3rd grader figured it out without help.Thor230 wrote:This is so freaking annoying the largest file you can upload is 512 megabytes and the smallest picture I have is 3.5gig so I'm not sure when the computer software was written for this website possibly 1981? Because I don't know of any modern day picture that's only 512 megabytes smh.....
Why would you even take such high-res shots? Crazy waste of your own storage
Re: Mistory cells?
The size limit is 512 Kb, NOT Mb. That is "KILO" as opposed to "MEGA".
There are numerous good reasons for a website to limit image sizes. Likely a waste of time to explain them.
The OP's link to original product purchased is no longer valid. They will have to make perhaps 30-60 seconds worth of effort to provide useful information which might result in useful answers.
Maybe invest in a spell checker, too.
"Not being treated like a dumb dick is one of the incentives we have to become less stupid." - Balmorhea.
Re: Mistory cells?
Takes a bit of learning to know how to ask questions in such a way that you are likely to get better / more answers.
Expressing anger at the world for things resulting from your own ignorance, is not conducive that way.
_______
How To Ask Questions The Smart Way
http://www.catb.org/~esr/faqs/smart-questions.html
_______
Re: Mistory cells?
This site can be a very unwelcoming place. It is indeed stupid that the size limit for pictures is so small. Sure a reasonable limit makes sense, but when you have to reduce an image to well below "cheap camera phone" size to post it, it makes more sense to just make it clear how to link images from other sites. It's funny: I used to always have a photo program with which I could reduce file size in seconds, but after several crashes and the obsolescence of the programs I was using, I don't have one either. So I link from Imgur.
And suggesting that a new poster here get a spell checker is hilarious. Why stick out like a sore thumb? You guys who are lambasting him for not being able to shrink photos are for the most part unable to or unwilling to use a spell checker and can't tell the difference between homonyms like "brake/break". It's embarrassing, frankly.
Re: Mistory cells?
There are **tons** of free and dead easy to use photo shrinker/resizers available for every. single. platform/OS
Post which you're on and help will be given.
I agree increasing to a reasonable max would be great, we can all ask the site owner pretty please, but in this case
the OP apparently expected **huge** photos to be accepted so that would not be a solution anyway, and hosting fees would def go way up.
I also agree IMGUR is a super solution.
As for unwelcoming, I think "teaching to fish" is not just appropriate but also necessary, when the noob is asking for significantly technical help but not providing enough info to get it.
- Dauntless 100 GW
Re: Mistory cells?
Ah, once again the usual suspects flock to the fight with no answer.
Any sufficiently advanced technology is INDISTINGUISHABLE FROM MAGIC!
- Arthur C. Clarke
- Arthur C. Clarke
Re: Mistory cells?
https://m.facebook.com/groups/DIYBATTER ... 331737649/
Here's a link to a Facebook post I made it about them that has pictures in it.
Re: Mistory cells?
I'm used to it there's a plethora of keyboard Warriors these days especially now that McDonald's has laid off so many of their employees due to the pandemic did they have extra time on their hands at their mom's house to do little angry masturbation and keyboard swashbuckling.
Re: Mistory cells?
I wouldn't necessarily call them huge photos I mean they're coming from a $75 phone but to each his own.john61ct wrote: ↑Nov 18 2020 4:10pmThere are **tons** of free and dead easy to use photo shrinker/resizers available for every. single. platform/OS
Re: Mistory cells?
Back in the day I used to use Photobucket but I'm not sure if that place is even around anymore?.LeftieBiker wrote: ↑Nov 18 2020 3:27pmThis site can be a very unwelcoming place. It is indeed stupid that the size limit for pictures is so small. Sure a reasonable limit makes sense, but when you have to reduce an image to well below "cheap camera phone" size to post it, it makes more sense to just make it clear how to link images from other sites. It's funny: I used to always have a photo program with which I could reduce file size in seconds, but after several crashes and the obsolescence of the programs I was using, I don't have one either. So I link from Imgur.
Re: Mistory cells?
Ignorance is not necessarily what is at play here because we are all lacking in information in some aspect on the internet and in life in general and so you could say we're all ignorant however I express my frustration because sometimes it is conducive if enough people agree upon the same frustration and or Express themselves as this can encourage the leadership of this page to make improvements in order to keep the people happy.john61ct wrote: ↑Nov 18 2020 1:58pmTakes a bit of learning to know how to ask questions in such a way that you are likely to get better / more answers.
_______
And this isn't a magician website I haven't provided enough information to expect a valid response with information that I so desire because the obvious reason (no photos) so I was not expecting any replies yet until I took the time to go back to 1986 and resize these photos
Re: Mistory cells?
Do you kiss your mama with that mouth? Sound like a bit of a little twat how old are you by chance?. FYI yes I can resize a photo I just didn't want to.Balmorhea wrote: ↑Nov 18 2020 4:15amLooks like you're the one who's out of date, of you can't even resize one of your own photos.Thor230 wrote: ↑Nov 18 2020 2:47amThis is so freaking annoying the largest file you can upload is 512 megabytes and the smallest picture I have is 3.5gig so I'm not sure when the computer software was written for this website possibly 1981? Because I don't know of any modern day picture that's only 512 megabytes smh.....
Re: Mistory cells?
Good for you. He also stopped eating his boogers? And pissing himself at night?.john61ct wrote: ↑Nov 18 2020 10:36amYes it is completely computer 101-level stuff to reduce the resolution of huge pics in order to send them over the internet, my 3rd grader figured it out without help.Thor230 wrote:This is so freaking annoying the largest file you can upload is 512 megabytes and the smallest picture I have is 3.5gig so I'm not sure when the computer software was written for this website possibly 1981? Because I don't know of any modern day picture that's only 512 megabytes smh.....
G I don't know I like good quality photos? And SD cards that have a lot of space on them are cheap now? And because everybody but you and your tasty paste eating kid that's "talented" with computers take high resolution pictures? .That's just a name a few.
Re: Mistory cells?
The price of the phone is not relevant
There is no place on the net but paid storage for photos that large, absolutely ridiculous.Thor230 wrote:the smallest picture I have is 3.5gig
Re: Mistory cells?
So post them?Thor230 wrote: I took the time to go back to 1986 and resize these photos
Also there are dozens of measurements that will help get the answers to your
oh wait you haven't asked any specific question yet.
The "ratings" of your Mistory cells are not what you need.
Your goal should be to learn how to actually measure their attributes and performance metrics
and then compare those to the requirements of your use case
which you should also describe here, if you believe members here are going to help you.
Re: Mistory cells?
Me? I date back to the ‘60s, and I can wipe my own without help.Thor230 wrote: ↑Nov 18 2020 9:56pmDo you kiss your mama with that mouth? Sound like a bit of a little twat how old are you by chance?. FYI yes I can resize a photo I just didn't want to.Balmorhea wrote: ↑Nov 18 2020 4:15amLooks like you're the one who's out of date, of you can't even resize one of your own photos.Thor230 wrote: ↑Nov 18 2020 2:47amThis is so freaking annoying the largest file you can upload is 512 megabytes and the smallest picture I have is 3.5gig so I'm not sure when the computer software was written for this website possibly 1981? Because I don't know of any modern day picture that's only 512 megabytes smh.....
___________
Re: Mistory cells?
When i mentioned the price of the phone i was implying that i by no means had the latest and most high resolution camera on the market. Do you have actual info on the original question ? If not move along
Re: Mistory cells?
I know how to "measure their attributes" however i wanted FACTS pertaining to things like the actual brand and model # and factory rating. So that i can compare the factory specs to the real world results for various reasons .john61ct wrote: ↑Nov 18 2020 10:41pmSo post them?Thor230 wrote: I took the time to go back to 1986 and resize these photos
Im a busy man and haven't found the time to frock with a photo sharing platform and so I don't expect any help or replies untill i do so.
