First Battery Build 21700 Molicel P42A
flippy   10 MW
Re: First Battery Build 21700 Molicel P42A
Post by flippy » Mar 23 2021 3:11pm
kudos wrote:
Mar 23 2021 2:26pm
I’ve had my lipo set at 3.67V LVC for years, with 32AH available and only taking half, I still get 20 miles which has been enough for me and cells stay balanced.
if you really want to prevent wear you put your LVC at 3.2V and stop charging at 4.05. you would be able to use more capacity and get even longer lifespan. or save a buck with a smaller battery. wich would be more useful i think. oversizing is great, but you can overdo it.
Lithium beats liquid dinosaurs.
kudos   10 kW
Post by kudos » Mar 28 2021 2:11pm
Just took the battery out for a spin, I hope you guys have somewhere you love to ride...
Build 1A Gary Fisher Wahoo Hardtail : Crystalyte HS3540 40A 49V
Build 1B Gary Fisher Wahoo Hardtail : Mac 10T 30A 49V
Build 1C Gary Fisher Wahoo Hardtail : Crystalyte HS3540 40A 82V
Build 2 Mountain Cycle Fury FS : Mac 8T 40A 57V : Scrapped
Build 3 GT LTS FS : Mac 10T 30A 49V
Build 4 EEB Frame: Mac 8T 40A 49V 32Ah
kudos   10 kW
Post by kudos » Mar 30 2021 5:16am
Change of plan.
Is there a meanwell that will do around 58V 8A?
flippy   10 MW
Post by flippy » Mar 30 2021 5:20am
kudos wrote:
Mar 30 2021 5:16am
put 2 HRP-300-36 in series. that set will do 9A all day between 57.6V and 79.2. just make sure you divide the voltage equally between them.
kudos   10 kW
Post by kudos » Apr 03 2021 6:07am
Battery now re-configured for 14S.
I have a cheap 4A charger arriving next week, if it’s good I’ll add another in parallel for 8A.
BMS should be here next week too.
kudos   10 kW
Post by kudos » Apr 06 2021 8:09am
BMS turned up today. Not bad really from China, ordered on 23rd March, only two weeks.
It came with absolutely zero instructions of course.
I’ve already managed to piece together most of the info I need, how to configure the balance harness for 14S:
The two temperature sensors are straight forward to install.
The one thing I’m not sure about is turning it on for the first time, do you need to actually install a button switch?
If so is it a switch or momentary switch?
Or can you just touch the on/off leads together once to get it going ?
flippy   10 MW
Post by flippy » Apr 06 2021 2:46pm
usually its just putting the charger on it for a second or so or just jump the red/black wire on the left side.
kudos   10 kW
Post by kudos » Apr 08 2021 11:19am
I’m up and running with the ANT.
I tried the on/off wires but it didn’t turn on.
So I plugged the charger in as per flippy’s suggestion and that worked.
I use iPhone so tried Pairing directly with Bluetooth but got ‘pairing unsuccessful’ error.
Tried XiaoxiangBMS, it found the BMS, connected but data wouldn’t transfer.
Tried ANT BMS app, connected up fine. Still finding my way round the app. It only balances under charge so I’m running a manual balance for now...
flippy   10 MW
Post by flippy » Apr 08 2021 11:37am
if shorting the wires does not work you probably need to put a couple volts on it. grab a 9v battery or a fully charged cell and use that.
balance when its full, not half full. half full does not mean much. dont start balancing until you hit at least 4v.
ps: iphone does nothing. you need android for it to work.
tmho   1 kW
Post by tmho » Apr 08 2021 12:46pm
kudos wrote:
Apr 08 2021 11:19am
I also use the ANT BMS. For the old version like mine, it is just for Android. For turning on, my seller's instruction was either plug in the charger, or you can connect a momentary switch and 12V or under (must not be over 12V, one cell of your battery should be ok) and press on the switch.
I found similar instructions from a lot of sellers from Aliexpress. May I know where and which model you buy so that we should avoid buying from that seller?
kudos   10 kW
Post by kudos » Apr 08 2021 2:07pm
I bought from an eBay seller which seems to sell all sorts of generic Chinese tech, the seller name is freshcue.
I purchased the 16s 80A version.
Having a dig around on other sellers pages I now see this:
I didn’t find this when I’ve looked previously.
st35326   1 kW
Post by st35326 » Apr 08 2021 8:43pm
I had that same one. Grab 3-5 volts off the first series group and run either the positive or negative to a momentary switch. press for 2 seconds (beep) should wake up the Bluetooth in the BMS. Holding for 5 seconds (beep) will depower the charge and output leads. Essentially putting the BMS into energy efficency sleep mode.
kudos   10 kW
Post by kudos » Apr 09 2021 2:55am
I have some momentary micro switches on the way, so I’ll hook one up when they arrive.
I have another question, The cells were all at around 4.1 volts, so I set off a manual balance because this was going to be their first balance. Around 0.017V difference.
It took a long time so, I ended up leaving the manual balance running over night.
When I checked this morning the BMS had turned off overnight, I used the charger to turn it back on. The cells were not quite balanced either.
My question is, is it normal for the BMS to turn itself off?
I thought once it’s on, its on, unless you manually turn it off?
Is there a setting I need to check?
TerrySavace   1 mW
Post by TerrySavace » Apr 09 2021 10:13am
Just fitted the same BMS to my first battery build - once you have switched on the BMS using a battery, you need to short the wires together to keep the BMS "on" - its actually on as the hours "on" still tick up - but the bluetooth seems to drop. So switch it on using a 3.5V or what ever battery you do, then remove the battery and join the two wires together
mxlemming   100 W
Post by mxlemming » Apr 09 2021 11:21am
kudos wrote:
Feb 10 2021 1:56pm
I've ordered 72 Molicel P42A 21700 which I'm planning to put together in 12S 6P
Sorry to hijack this... Could you share the exact dimensions? Diameter especially... I'm looking to build 20s4p of these and need to know because I'm going to 3d print a triangle rack for my bike.
These are sadly pretty much the only cells available now in the UK. But they seem pretty good!
The Earth is flat. Flat flat flat. How would transistors work otherwise?
kudos   10 kW
Post by kudos » Apr 09 2021 1:16pm
Sorry they’re all wrapped up in the pack now so I can’t give exact dimensions....
Only cells left on fogstar, but they are supposed to be good.
