So I think I have managed to find out what causes all these odd problems.
I have another 10 packs like this to handle and figure out. My assumptions after today are as following:
The cells are the culprit. I assume the cells are rewrapped and recycled LG M26 cells which is the worst cell ever created as their behaviour makes them not worthy of being mention and or used as batteries. They will self-discharge, I suspect, they age different and odd so one cell can be 500mah and or 1200mah whilst others can be around 2000-2500mah. A BMS can´t handle this as this creates too much voltage differences between the cell groups.
The issues that have arisen are similar to the LG M26 cell but might not be exactly that cell as I thought just a moment ago. I will open it up to see if there is any codes or letters on it.
The letters on the metallic are nonexistent. No letters or any writing on the cell surface. However, on the purple plastic, there is this text on a cell I choose: 02ICEAGZ3124A29C20002189 and also the positive side protection plastic has a light blue color.
Weight is 44g (1,552 ounces)
Estimated capacity of 2500-2600MAH from factory.
Looking at the positive pole it looks like LG M26 cell but no evidence more than that and that the positive ring color is blue like an intel inside core logo doesn't give enough to really really be assured that it is.
Before I said they were:
leffex wrote: ↑Mar 12 2021 5:01am
The cells are FST brand 2500MAH 10A chinese power cells. I don't remember its last name code.
Though that has changed as can be seen by the last post. Earlier batches had been the FST 2500. These are unknown at the moment.
