Hello,
Has anyone come up with a practical way to use spring coils as serial connector between cells in large battery packs ? It's quite common in cheap 1 to 4 cells holders, but I have never seen a large pack built with such a system. The reason I'm thinking about building one is because the current battery geometry I'm facing would favor stacking cells atop another instead of next to each other like in a classic rectangular box. Using coil springs between the cells seems like an option, especially based on brass wire (or fancy beryllium Cu!).
Open questions remains though, like how to easily connect the coil to each other (parallel wiring for balancing) and more importantly, is there a real risk of contact braking in high vibration or shock environment ? After all, the coil would only push against the cells, and not be soldered to it.
Thanks for for your feedback,
qwerkus
qwerkus
