bms bluetooth connecting problem
ahmedalasadi   100 µW
100 µW
Post by ahmedalasadi » Jun 05 2021 6:19am
Hi.. today i tried to connect my phone with bms via BT but .. the phone BT can recognize it but the apk can't :| !!.. tried to reinstall it again and the same problem exist .. tried install it on another phone and also can't connect it with bms apk .. does yhat means a problem with bms it self !?? as U can see in the attached screen shot .. any help will be appreciated ..
john61ct   100 GW
Re: bms bluetooth connecting problem
Post by john61ct » Jun 05 2021 10:49am
look for other APK versions
ahmedalasadi   100 µW
100 µW
Post by ahmedalasadi » Jun 07 2021 1:54am
john61ct wrote:
Jun 05 2021 10:49am
I did .. updated to 1.92 .. and the problem is still 😕!!..
john61ct   100 GW
Post by john61ct » Jun 07 2021 10:48am
Keep going back trying older ones
pwd   10 kW
Post by pwd » Jun 08 2021 10:00am
Are you able to pair with the BMS first before opening the app?
2WD Commuter/Street Build viewtopic.php?f=6&t=98286:
Rocky Mountain Element
Magic Pie 4 front w/ Infineon 4 Clone @ 70A phase + Leafmotor 1500 rear w/ Infineon 4 Clone @ 200A phase
Samsung 40T 14S7P
Offroad Build viewtopic.php?f=6&t=102195:
2019 Rocky Mountain Blizzard 20
Cyclone "3kw" 13T motor to 36T chain ring then 32T chain ring to 11T-46T Cassette @ 100A phase
Molicel P42A 21S3P
ahmedalasadi   100 µW
100 µW
Post by ahmedalasadi » Jun 08 2021 11:54am
john61ct wrote:
Jun 07 2021 10:48am
I did too ..but didn't find it .. i looked for v1.0.7 .. but got nothing 😥!!..
john61ct   100 GW
Post by john61ct » Jun 08 2021 11:56am
Different phone / Android version?
$20-30 on eBay
ahmedalasadi   100 µW
100 µW
Post by ahmedalasadi » Jun 08 2021 5:57pm
pwd wrote:
Jun 08 2021 10:00am
I connected with BMS more than 5 times .. suddenly it stopped .. though my phone BT recognize the BMS BT module serial number .. but the APK not ..
Mart76   10 mW
Post by Mart76 » Jun 10 2021 12:46am
This is the daly app for their smart bms, right?
ahmedalasadi   100 µW
100 µW
Post by ahmedalasadi » Jun 10 2021 1:35am
Mart76 wrote:
Jun 10 2021 12:46am
YES .. the Basen Co. selling agent called "Sheila Chou " on Alibaba site tried helping me as much as she can in this matter thankfully by but didn't help too .
ahmedalasadi   100 µW
100 µW
Post by ahmedalasadi » Jun 10 2021 1:37am
john61ct wrote:
Jun 08 2021 11:56am
$20-30 on eBay
: :!: :!: :!: :?: :?: ..didn't understand U
Mart76   10 mW
Post by Mart76 » Jun 10 2021 1:47am
So why did you not put that very evidently important information in the header. Do you think all bluetooth bms use the same app or behave the same?
The header of posts need to be concise and informative, so other users can easily search for answers in forums. That is the very basic idea of such forums. If you dont get that stay out of it!
I probably have the solution for your problem, but I am hesitant to share because of your behaviour. Which, by the way, is why I share very little of my knowledge here. To many users not grabbing the basic ideas of forums.
ahmedalasadi   100 µW
100 µW
Post by ahmedalasadi » Jun 10 2021 8:26am
Mart76 wrote:
Jun 10 2021 1:47am
Listen well . I looked for a solution .. found this site and registered .. looked for a way to post like others did i found it and no one complained like U did and they tried thankfully gives a hand of help ..if U don't like to help for any reason or found something in this post don't comply with your posting criteria so U can simply leave it .. hope U get the point pal !!..
Mart76   10 mW
Post by Mart76 » Jun 10 2021 8:41am
That is the problem. Too many people around not thinking twice about what they do and demand from others. Dont take it personally, you are just one of many, as you so correctly stated.
Not even thinking about what I wrote or having the guts too simply admit that I might be right.
In that case....good luck with your problem. I will certainly not help you out.
john61ct   100 GW
Post by john61ct » Jun 10 2021 8:05pm
ahmedalasadi wrote:
john61ct wrote:
Jun 08 2021 11:56am
$20-30 on eBay
Use a different phone.
If not a different iOS version
then Androids are super cheap secondhand on eBay
Mart76   10 mW
Post by Mart76 » Jun 24 2021 3:28am
absolutly amazing! It is so easy to solve. I am having a ball!
