R4875G1 - How to switch on?
Darren2018
I recently upgraded my R4850G2 to a R4875G1 and I am wondering if I can jump the same pins to get it to switch on. Usually it is the pre charge pin and main DC ground to the slot detection pin. On the R4875G1 the board and pads are slightly different so the control unit is probably different. I thought I would check to make sure.
R4850G2
R4875G1
The R4875 uses the same pinout for startup like the r4850. Only to get the full 4kw you need to bridge to contacts. It is all written ans pictured in the r4850 thread
