batteryGOLD
MotoJet board value $15k to surf at Algarve PT beaches does not work..
Starter KO
This starter has 4S Samsung 40T 4000mAh 35A cells
Check picture testing new Sony mobile. Using wide angle lens cells looks like 18650..
load full resolution..
https://ibb.co/vPWf8sp
Problem: Starter does nothing..
Cause: one cell down to 1V bms went down
Solution: balance cell to equal others, and check IR . cell ok 10mohm similar to others
Final result : Board motojet does start OK, problem solved. but need water isolation compound at closing enclosure
Starter KO
