I received both quote from them but i still never had any experience with them.
This is me that annoubced about ecity (BMSbattery) here and it seems that we have a great % satisfaction and this is great!
it appear that ping is also still supplying great products.
I will need 7 x 48V16Ahbattery with 40A continuous BMS and discharge rate and a good 5A charger.
You know that i dont have any time to built them myself and test every single cells like i did with my own pack and that's the reason why i need to order and buy them.
I need your own opinion about both compagny
For me here is the advantages of each compagny:
Ecity:
pos- people seems generally satisfied with their battery
pos- the service seems good
pos- the communication i had with Jack is good but it take alot of time(skype) to ensure Jack understand exactly what we want!
pos- the packaging is good
pos- the construction of the battery case with thick shrink is good
pos- the bms is inside the battery and seems protected
pos- they seems open to add some special demand regarding the battery construction like fiberglass to renforce the case
con- the anounced spec of C rate about the cell is diffenrent than the C about the battery
con- the 5A charger seems having some problems reported
Ping
pos- they seems good about R&D and they upgrade their product with new version.
pos- the service seems very good ( 100% on ebay)
pos- the communication i had with Ping is excellent
Pos- the BMS is accessible and have now LED for disgnostic
con- the construction of the battery case with fragile thin blue shrink
con- the bms is OUTSIDE the battery and seems not very protected
here is both of the battery to show you the differences:
Ecity BATTERY
