garolittle
Question for the experts: Assume the use of 32650 Lithium Iron Phosphate (LiFePO) Cells. The cells do not have the original plastic a ring gasket but will be re-wrapped with have a paper “stick-on O-ring gasket” (see green arrow below) as well as a 3-D printed gasket (red arrow below) that will sit on top of the paper stick-on. Finally, a .25 mm thick copper sheet will be spot welded onto the cells using a pulse arch welder. There will be an aluminum bar (yellow arrow below) which uses rivets to connect to the other side (anode) of the pack (ie the rivets run through the spaces between the cells to connect to the other (negative/anode) side.
What are your thoughts on this design?
