How can a battery pack all of a sudden get this unbalanced? I know it's a difficult question, but it could give me some hints
The cell groups measure voltage:
3.13 (+)
3.12
3.06
3.4
3.6
4.09
3.98
3.92
3.98
4.07
4.08
4.08
4.08
4.10
Yes, some BMSes draw their power from just one or two cell groups rather than the whole pack, so over time those groups get drained down if the battery isn't periodically cycled and balanced. A malfunctioning BMS can leave the bleed resistor on for any (or all) of the cell groups and drive them to 0V. I have run across both these things several times when diagnosing misbehaving packs.
Does anyone really know what is "working right" when it comes to relatively inexpensive BMS discharge balancer or even an expensive so-called 'smart' BMS. Sometimes the BMS is OK, and the fault is with the cells in the pack.
Active balancer boards provide full time cell voltage detection, plus balancing when variation exceeds 30mV, at any state of charge. They balance at a current of up to 1.2A (or more for some boards), though surely this value is much lower for small voltage differences. They go back to standby when the cells come within a 10mV range. They are rated to consume 25 μA or less while standing by.eMark wrote: ↑Oct 20 2021 8:33amWhether using a RC Li-po "Blinky" or inexpensive Li-ion BMS neither is a cure for 2nd rate cells and/or pack abuse. What i mean is that with 2nd rate cells or an abused pack it isn't possible to balance the p-group cells within 25 to 30mV of each other no matter how long (i.e. weeks--months) is the BMS discharge balancing. Not sure about "active" balancing, but probably the same.
Ah, but when you eliminate that suspect... then you become the person of interest.spinningmagnets wrote: ↑Oct 20 2021 12:49pmIts been commonly posted that "BMS" stands for battery management system, but...ebike mechanics and design engineers have told me it actually stands for Battery Murder Suspect.
Do with this knowledge whatever you wish...
"I have met the enemy, and he is us" - pogoBMSes are not so much for the benefit of the battery, as they are for somewhat protecting the battery from the user
If you're asking me.
