garolittle
Question for the experts. I have a 15S/30P configuration of lithium iron phosphate (LiFePo4) cells. These are cylindrical K2 cells which I have connected with a spot welder. I carefully checked the voltage of each cell before spot welding and all cells were within an acceptable voltage range of each other. Nominal voltage for the pack is 48V and maximum voltage is 54V. There is very little variation between the voltages of the 15 parallel groups of cells within the pack. Basically the individual cell groups are within 30 mV of each other. I have not fully discharged the pack yet but I noticed that after charging the pack it up to 54V, the pack eventually settles back down to about 50V or 51 V. Is this common for new cells that have yet to be discharged? Thanks for any suggestions you may have.
