Overview: best rectifiers for charging (voltage mod) - Eltek/Delta/Huawei/Emerson/Vertiv
Tomblarom   10 W
Post by Tomblarom » Jan 21 2022 10:30am
I couldn't find anything like this and made this for myself to compare common telecommunication PSUs / rectifiers. Trying to update this frequently. Used datasheets attached. Enjoy!
Eltek
Code: Select all
  Model        Power   Size               Voltage        C@48v   Eff.    Weight   Public Protocols
  48/1000 HE   1000W    72.0×41.5×217.0   43.5 - 57.6V   20.9A   95.5%    850g    CAN, I²C
  48/1800 HE   1800W    72.0×41.5×217.0   43.5 - 57.6V   37.5A   96.0%    850g    CAN, I²C
Emerson/Vertiv
Code: Select all
  R48-1000e3   1000W    52.0×41.0×152.0   42.0 - 58.0V   20.8A   95.4%    600g    Nothing yet
  R48-2000e3   2000W    84.5×41.0×252.5   42.0 - 58.0V   42.0A   96.2%   1130g    Nothing yet
  R48-3000e3   3000W    84.5×41.0×330.0   42.0 - 58.0V   62.5A   96.0%   2000g    Nothing yet
ImPow
Code: Select all
  R481200H1   1200W    70.3×42.5×253.0   42.0 - 58.0   25.1    96.0%   1000g    CAN
  R482000H1   2000W    70.3×42.5×286.0   42.0 - 58.0   41.6    95.0%   1300g    CAN
  R483000H1   2000W   106.0×42.5×286.0   42.0 - 58.0   62.5    96.0%   1900g    CAN
Huawei
Code: Select all
  R4850G2   3000W   105×40.8×281.0   42.0 - 58.0   62.5A   96.0%   2000g    CAN
Delta
Code: Select all
  ESR-48/56    2880W   125.0×41.0×269.9   40.0 - 59.0V   55.0A   91.0%    2000g    Nothing yet
--> You can find a lot more results on mods using "model + 改可调" which means "voltage mod".
ImPow R483000H - Datasheet.pdf
(747.38 KiB) Downloaded 7 times
Eltek Flatpack S 48v.pdf
(300.88 KiB) Downloaded 7 times
Huawei R4850G2 - Datasheet.pdf
(598.96 KiB) Downloaded 5 times
Huawei R4850G2 - User Manual.pdf
(466.68 KiB) Downloaded 7 times
Delta ESR-4_56A C - Datasheet.pdf
(117.05 KiB) Downloaded 5 times
ImPow R481200H - Datasheet.pdf
(733.58 KiB) Downloaded 5 times
ImPow R482000H - Datasheet.pdf
(775.37 KiB) Downloaded 6 times
Vertiv R48-2000e3 - User Manual.pdf
(609.92 KiB) Downloaded 6 times
Vertiv R48-1000e3 - Datasheet.pdf
(709.39 KiB) Downloaded 8 times
Vertiv R48-2000e3 - Datasheet.pdf
(599.87 KiB) Downloaded 8 times
Vertiv R48-3000e3 - Datasheet.pdf
(5.82 MiB) Downloaded 7 times
Vertiv R48-3000e3 - User Manual.pdf
(915.29 KiB) Downloaded 7 times
john61ct   100 GW
Re: Overview: best rectifiers for charging (voltage mod) - Eltek/Delta/Huawei/Emerson/Vertiv
Post by john61ct » Jan 21 2022 11:15am
WOW excellent resources, thanks so much for contributing this!
48V is a sweet spot for "backbone" distribution, minimizes distribution losses using cables with lower currents bussed throughout the system using smaller, less expensive conductors
then using quality DC-DC chargers & converter modules close to their loads as secondary voltage sources.
Tomblarom   10 W
Post by Tomblarom » Jan 21 2022 11:44am
john61ct wrote:
Jan 21 2022 11:15am
And for charging Li-Ion. :wink: Up until 14S (58.8v).
