Exact Connector used on DALY BMS (Answer not Question)
methods
1 GW
Santa Cruz CA
You can use this Google Search to buy a preformed whip
https://www.google.com/search?q=DALY+BMS+cable
You can find the OEM here
https://www.lhecn.com/a2005/
The company is LHE and they DO make a 17pin version even tho the datasheet reads only up to 16pin
Here is the stamping on the housing landed from DALY
file.php
That is how I K N O W it is LHE and not one of the other two clones. Anyway, it is a very standard 2.0mm pitch but with a locking latch. I do not know of a US replacement.
You are welcome, OK BYE.
-methods
