Ping V2.5 Reports
JinbaIttai   100 W
Ping V2.5 Reports
Post by JinbaIttai » Sep 30 2009 5:39pm
Since we have a V2.0 reports thread and a V3 reports thread, we should have a V2.5 reports thread.
Have any V2.5 users had any issues to date?
Please update us on your V2.5 condition.
Chassis: Schwinn S-30 Engine: Ampedbikes rear hub Fuel system: Ping 48V 20AH V2.0 split in half
Lighting:One P7 flashlight, One SST-50 flashlight, Two Planetbike Superflashes
As of April 30:
Battery: 955 miles and 88 cycles--5 dead pouches replaced to date
Motor: 1215 miles
JinbaIttai   100 W
Re: Ping V2.5 Reports
Post by JinbaIttai » Oct 02 2009 8:40pm
Not one single ping 2.5 user on the entire forum?
As of April 30:
Motor: 1215 miles
lesspedal   100 W
Post by lesspedal » Oct 04 2009 10:02am
What is the difference between 2.5 and 3.00 ?
200w elation v3
2oow Gette
dnmun   100 GW
Post by dnmun » Oct 04 2009 1:18pm
none. the v3 lifepo4 packs use the v2.5 signalab BMS, and the v3 pouches are upgraded from the v1 packs to 3C i think is how it works.
wineboyrider   100 MW
Post by wineboyrider » Oct 11 2009 9:40pm
Last I checked there is no v3.0 ping battery. I have v2.0 and v2.5.
Russell   10 MW
Post by Russell » Oct 11 2009 9:51pm
wineboyrider wrote:Last I checked there is no v3.0 ping battery. I have v2.0 and v2.5.
http://www.endless-sphere.com/forums/vi ... 14&t=12949
-R
Jeep Comanche Trekking Bike w/YOUE geared motor, 42 lbs + 15 lb rear trunk bag w/12S 16Ah LiPo battery, tools, etc., 21A controller, 700 x 40C tires. 27 MPH.
My other E-Bikes: Nashbar Steel Flatbar
mrbill   10 kW
Post by mrbill » Oct 11 2009 11:13pm
I'm about to order a Ping V2.5 24v/25Ah battery. Will this battery discharge 40A from 100% to 20% SOC (state-of-charge) without dropping its voltage below 24 volts?
Bill Bushnell
http://mrbill.homeip.net/
Bike build thread can be seen here.
dnmun   100 GW
Post by dnmun » Oct 12 2009 2:05am
bill, i don't think any lifepo4 cell can do that. seems like they all were below 3V when they reached 80% discharge. go look up drbasses comparisons using his CBA, and i think they all were below 3V by then.
but not by much.
BMI   100 W
Post by BMI » Oct 12 2009 4:28am
dnmun wrote:bill, i don't think any lifepo4 cell can do that. seems like they all were below 3V when they reached 80% discharge.
Not true actually.
According to the cell discharge curves the new LiFeTech packs are still no lower than 24V at 80% discharge and this is with a smaller 15Ah pack. This is at a 3C discharge rate (45A) so the expected voltage with the even bigger packs of 20Ah or 30Ah the figures should be even better than for a 15Ah pack.
moostrodamus   100 W
Post by moostrodamus » Oct 12 2009 10:32am
I have a ping 2.5 48v 20ah pack with about 2000km on it. Works fine. Charger fan makes noise now for the first minute of charging, then settles down. Probably order a spare charger.
Commuter: Crystalyte HS3540
Infineon 40 amp controller
Ping V2.5 48v 20ah
docnjoj   100 GW
Post by docnjoj » Oct 12 2009 2:34pm
I'm not sure if I have a 2.0 or a 2.5 Ping. Got it last November but took it off the trike in July/Aug when I got the fatpacks. It is just too big! I do miss the power, though! It stays in the house and gets charged 1x per month. Only has about 30 cycles because of my December accident. Seems great but no place tomount it on the new trike.
otherDoc
E-bike stable at our house
Steintrike Mad Max full suspension trike rear Cute 100H going on: Whoops, Cute wheel broke but I fixed it.
Sun USX delta trike EbikeKit small geared front wheel sort of front suspension for wife
Agniusm/A123 AMP 20 36 volts on the Steini has been taken off.
2x16000 Multisport from HK now gone as they died after 2 years
New Luna 10S bottle battery 13.6AH now on mine
Relatively New 10S4Px2 for wife's bike giving 20ah @ 40 volts home made Panasonic from Tumich. BMS's rule.
mrbill   10 kW
Post by mrbill » Oct 12 2009 4:18pm
dnmun wrote:bill, i don't think any lifepo4 cell can do that. seems like they all were below 3V when they reached 80% discharge. go look up drbasses comparisons using his CBA, and i think they all were below 3V by then.
but not by much.
According to drbass's report in the archive the PSI 10Ah cell at 20A (equiv. to 20Ah double-cell at 40A) was delivering just under 3v at 20% SOC. My own packs made with the older green PSI cells confirm his results. Of course, that is measured at the battery and does not include the effect of the BMS FETs, connectors, and the wire, which for me are about 0.6 - 0.8 volts of additional drop altogether.
I asked because Ping claims that his V2.5 pack at 25Ah will deliver 40A down to 20% SOC, and I wanted some independent verification.
Bill Bushnell
Vim   10 W
Post by Vim » Oct 13 2009 12:39am
moostrodamus wrote:Charger fan makes noise now for the first minute of charging, then settles down. Probably order a spare charger.
Mine was doing that. Someone here at the forum told me to get to the fan, peel the little round sticker back to expose the axle bushing, put a drop of oil in it, and press the sticker back on.
It worked like a charm...still quiet now months later :wink:
Vim
dogman dan   100 GW
Post by dogman dan » Oct 13 2009 6:44am
Ping has never exaggerated what his batteries could do. To the contrary, he usually recomends a bit larger size that most people actually buy and use. There is a big difference between pings claims and some others from ebay.
dnmun   100 GW
Post by dnmun » Oct 13 2009 10:46am
i just used a ping v2.5 signalab BMS with the leds for the first time. i have a pack which had balancing problems and was ending up short of capacity because the low cells were so far from the high cells that were shutting down the charging FET at HVC and limiting the capacity .
i added the ping v2.5 signalab and watched as the cells finally started lighting up their leds over a reasonably long period of time until they were all lit and i checked, first time to balance under the new BMS and all were within 1%.
i have done 2 discharge/charge cycles since and now all the leds are igniting within a minute it is so closely balanced now. maybe another .1Ah of charge after the first led lights up to when the the last lights up and then it starts regulating the charging FET. i think with another 3-4 cycles it will be totally balanced. all light up essentially together. 43.8V. perfect.
the shunt current is about 68mA, which seems about right if you give the led 4mA and the other 64mA goes through the 5 330 ohm surface mount resistors in parallel. cycling about once/second.
i could not have had a better first impression of mr ping's v2.5 signalab. i could not detect any heat, none at all in the charging FET. but i was only pushing 3A but i don't think it would have gotten hot pushing 10A, just a well made BMS.
i got it because it was so cheap, but after looking at some of the other BMSs, i think this v2.5 signalab is exceptional.
the leds are really useful to help understand how the pack is balancing. the sequence always starts with the same led because i have one cell that gets to the top first, and then bam, 4 more, then another 4-5, then a little longer for the last 2. always the same pattern. this is so useful it would help if people would keep track of it and if it changes during the life of the pack then you know something is changing on that cell. all imho.
snowranger   10 kW
Post by snowranger » Oct 13 2009 3:30pm
Would you say the V2.5 BMS is better than the Headway's 48Volt one? That one is rated for 60-80 amps I think.
Electric: BBS02 / Nuvinci Developer Kit / 14s Li
Bike : Yuba Mundo
Accessories: 12 volt lighting, 48V horn
Miles: 300 mi
dnmun   100 GW
Post by dnmun » Oct 13 2009 3:59pm
that's not fair, you know how much i like the headway BMS, which is huge compared to the signalab, with its big heat sink plate on top.
i really really like the leds though. when you shut down the charge and leds start flickering on and off, it is like they are singing to you. little light show. little twinkling stars running back and forth until they all drop down below the conduction voltage for the led and it shuts off.
but the headway must cost twice as much. we only were able to get the deal we did because travis was able to strike such a good deal for us with headway.
i can't imagine headway is selling their BMS for less than $90-100. i guess i should check. i'm sure someone will yet.
ElementX   1 W
1 W
Post by ElementX » Oct 13 2009 5:57pm
I ordered 3 ping v2.5 packs about 4-5 months ago and requested them to be 12v 15ah. My plan was to use them in series on my ebike, and then also use them in parallel for my 30lb electric trolling motor. As always, things come up in life and I didn't get around to using them immediately. I checked them all for voltage when I got them, but then they sat for about 2 months before I used any of them. When i did, I only used 2 of them no my 24v 350w cyclone motor. So far, I've only ridded less than 5 miles on maybe 7 different trips. I recharged them after each trip and they are working fantastic.
The 3rd battery I just pulled out of the closet yesterday. I stripped the ends of the charging wire and hooked them up to my charger. I had purchased 12v chargers from ping. Label reads "input: 1.5A, output: 15.4v=5A" It only took about an hour of charging before the leds came on, but I'm concerned that this battery pack has a problem. Only 2 of the leds came on solid, no other leds on this pack are lighting up. The 2 packs I've been using have 4 leds that go solid when its about done charging.
Has anyone run into this issue before? I used my DM to check the voltage on this pack with the 2 leds and its in line with my other packs. Do I have a problem with the BMS?
dnmun   100 GW
Post by dnmun » Oct 13 2009 7:48pm
why didn't you just convert the trolling motor to 36V. that woulda been easier. hehe, no really.
the leds should turn on, but you may need to cycle it a few times through some discharge/charge cycles. so mount up your trolling motor on the kitchen table and run it for awhile, then recharge/discharge/recharge but it doesn't take much discharge each time just 5-10%.
then see if another or all of the leds turn on.
ElementX   1 W
1 W
Post by ElementX » Oct 29 2009 1:26am
dnmun, looks like you were right. It just needed to be cycled a few times and now all 4 leds are on. I still haven't actually used this 3rd batt yet, but its looking normal now. I actually just unplugged my charger from the wall, but left it attached to the batt and that seemed to help it out. The batt would power the green led on the charger and then eventually the red leds on the batt would go out. I plugged the charger back in each time this happened and let it sit overnight before doing this again. After I did this for the 3rd time, the 3rd led lit up, then the 4th led came on shofrtly afterwards. Thanks!
pvorlicek   10 W
Post by pvorlicek » Nov 09 2009 5:42pm
dnmun wrote:i just used a ping v2.5 signalab BMS with the leds for the first time.
Dnmum:
Where did you purchase the version 2.5 BMS? What did you pay?
Thanks,
Preston
moostrodamus   100 W
Post by moostrodamus » Nov 20 2009 5:22pm
So...I mentioned in a post earlier that my fan on my charger for my Ping V2.5 was making noise...i didn't get a chance to read the helpful advice to put oil on in this topic and well...it died.
I wrote to ping and he sent me a new one for free...well 20 bucks for shipping as i went ahead and ordered a extra charger and bms along with the replacement charger (just in case). Took a week and a half to get here to Toronto.
Rode to work this am, was about 6 degrees C. Felt great not to be among the sweating bus mass...maybe i'll write a BusMass Carol...hmmmm
I'm a happy Ping customer.
Moo
Ping V2.5 48v 20ah
moostrodamus   100 W
Post by moostrodamus » Nov 20 2009 5:51pm
Buss Mass Carol:
RING THE BELL
(sung to "Jingle Bells" tune)
Ring the bell,
Ring the bell,
Get off the freaking bus.
Your pits are rank,
Like a dirty fish tank,
It really is to much...
HEY!
Ring the bell,
Ring the bell,
Your thigh sweat is soaking through,
And getting on my pants.
Dashing down the road,
With a nine C electric kit,
Passing the bus stop,
They can eat my shit...
HA HA HA
There's no sweaty bums,
No farts or coughing fits,
Just as long as it doesn't snow,
I'll ride my nine c kit...
Oh...
Ring the bell,
Ring the bell,
Your pits are rank,
HEY!
Ring the bell,
Ring the bell,
By Moo
Ping V2.5 48v 20ah
Ultraman   1 W
1 W
Post by Ultraman » Nov 20 2009 9:38pm
Haw. I'll keep an eye out for your ride when I'm on my 9 c kit with my ecitypower LiFePO4 pack. We can sing your carol together as we pass the losers on the TTC.
Vector frame, Adaptto Mid-E, MXUS 3k.
Tidal Force IO Cruiser, Lightning Rods mid drive.
moostrodamus   100 W
Post by moostrodamus » Nov 20 2009 10:09pm
I can be found doing "The Kennedy Death RUN" from Danforth to Steeles daily...Merry Busmass!
Ping V2.5 48v 20ah
