flashedarling
- Joined
- Jul 21, 2008
- Messages
- 49
Ok, this is a question that I've been flipflopping on for about a year now. So far I've been able to put it off by saying "Oh, well I don't really need the batteries until X is finished" but now it is the home stretch, I've got everything I need except the batteries. So for my motorcycle with a 72V 60AH pack do I go with Thundersky or Headway. The choice is between getting 24 60Ah TS cells or getting 144( ) Headway cells. (Although if I went headway I'd probably make only a 50AH pack to start and then add another 10AH later if I needed it)
The advantage of Headway seems better performance, but it is more expensive and although I've seen it done in the "Headway Pack Builders" thread it seems pretty troublesome to make a large pack of them like this. Given the rate I work at it might be large enough an obstacle to prevent me from getting this thing on the road anytime soon.
Also there are now those LiFeYPO4 Thundersky cells which promise better performance than the older thundersky cells. I don't have any realworld experience to back this up but I'm under the impression that motorcycles will be pulling 70-80 amps continuous and 200-300 amps peak, which seems like it should be within the limits of a 60AH thundersky cell. The only thing that makes me hesitate is the fear of getting the AH calcuations wrong, I'm trying to get around 50 miles a charge on this thing) and needing to expand the pack. It seems to me that it would be easier to add more headways to a headway pack than TS cells to a TS pack, but maybe I'm wrong there too.
Can anyone offer advice to help me break my decision deadlock?
