Dealing with 8 guage wire on 30c turnigy packs
dogman dan   100 GW
Post by dogman dan » Jun 10 2010 2:47pm
When my lipo blocks arrived, I got caught a bit unprepared since I hadn't noticed that in 30c the turnigy comes with an 8 guage wire and huge bullet connector.
The controller I plan to use is 45 amp, so I really don't need to use mondo huge wire for this bike. 12 guage should be ok for this, I think.
Putting a 45 amp anderson on it as I wanted became pretty difficult, in fact dang difficult. I couldn't charge em up very easy till I did something, at least getting one adapter made for hooking up the series connected packs to the controller on a bike, and for hooking to a charger with andersons on it.
At the Lowes electrical section, I found just the thing since I am a real klutz with a soldering iron. 18-10 guage crimp connectors. These allow me to crimp up a connection for a 12 guage wire to an anderson, and a second wire to go to my cheapo low voltage alarms.
Crimp sleeves.jpg (49.45 KiB) Viewed 680 times
Cut off the bullet connector, and strip about 3/8 inch of insulation off the three wires, and crimp with a cheap crimper. The kind with a bump that sort of folds the crimp into a V shape, and then using the other part of the jaw, fold the V closed for a super tight crimp. Easy as pie.
Crimping the sleeve.jpg (67.63 KiB) Viewed 680 times
Finished crimp.jpg (50.33 KiB) Viewed 680 times
Finish of with shrink tube of course, but other methods could be used. Now I have an easy to replace when needed 45 amp anderson on 12 guage wire, and the extra wire to connect to a plug that will go to my lv alarms to be mounted on the handlebars.
shrink tube cover.jpg (58.87 KiB) Viewed 680 times
Ykick   100 GW
Re: Dealing with 8 guage wire on 30c turnigy packs
Post by Ykick » Jun 23 2010 7:45am
Aren't we supposed to nip through both black/red wires at the same time? LOL...
Thanks for the good tip(s)
- Frank Sinatra
dogman dan   100 GW
Post by dogman dan » Jun 23 2010 4:07pm
Done it a few times with 110v AC wires. Hard on the pliers. :lol:
heathyoung   1 MW
Post by heathyoung » Jun 23 2010 10:18pm
dogman wrote:Done it a few times with 110v AC wires. Hard on the pliers. :lol:
Do it on 240V and you have yourself a pair of wire strippers.
GNG offroad build on Craftworks DHR with 12S2P lipo. Light, balanced, powerful, able to climb a tree.
Project Vectrii (2) - status - Finished. Nope. 38S Leaf cells are next. Now have 2 of them - Averages 50Wh/Klm
dogman dan   100 GW
Post by dogman dan » Jun 24 2010 6:31am
Yeah, I have made a few pairs of wire strippers. Now I never believe it when somebody says a circuit is off. Did it with 240 once with a hammer drill, that was fun. Had to leave the drill bit stuck in the concrete since it welded itself to the steel conduit I drilled through. The poor Mcdonalds couldn't serve fries for a week.
