Hyperion EOS 1420i NET3 14s Balance Charger...
maca55   10 mW
Re: Hyperion EOS 1420i NET3 14s Balance Charger...
Post by maca55 » May 16 2014 4:22am
Ok so the cracked IRFB4110 and the IRF4905 were as expected internally shorted between all 3 pins. Also found two fried resistors R39 & R54 - see pic. They looks be 10ohm so probably the gate drive resistors? One is open and one is short circuited.
The shopping list is growing. So do I try the cheap eBay FETs for $1&2 ea or the genuine IR ones for $4&8??
Gate Resistors
pguk   100 W
Location: North England, birthplace of the Industrial Revolution
Post by pguk » May 27 2014 7:37pm
maca55 wrote: I have three 1420s. The first has blown what looks like multiple FETs and no longer works. The second still works only when the output voltage exceeds the input voltage eg) 4S or more when using a 12v supply, or 8s or more when using a 24v supply. The third one is still working fine apart from it no longer being detected by the eos data suite.
http://www.wheelchairdriver.com/hyperio ... ersion.htm
Here is a link to a blog detailing how to convert a 1420i to Bluetooth. I ordered the parts today. After around 18 months fairly light use my unit has begun not to be recognised by the EOS data suite also, possibly due to ground loops... The computer itself is seeing the unit, only the software isn't recognising it.
6pence spot welder https://endless-sphere.com/forums/viewt ... 31&t=81274
"It is all nice and proper, but only an idiot would think that the father is sixpence to the good on the transaction." C.S. Lewis' Mere christianity
dnmun   100 GW
Post by dnmun » May 27 2014 8:00pm
R39 and R54 are both 100, 10R on mine too.
ninja007   100 µW
100 µW
Post by ninja007 » Jun 20 2014 9:28am
My Hyperion is toast, actually many months ago this happened so my memory is a little fuzzy,
I was going to try to save a 4S2P A123 motorcycle battery I made that I had over-discharged, and i'm pretty sure it was when I plugged in the server PSU to the hyperion, it went up in smoke... Its still powers on, but will instantly throw up an error, something along the lines of "warning, high temperature limit exceeded" and just keep flashing that message up there. I took it apart and can't see anything obviously fried, but I definitely smelled smoke when this happened.
Any idea's? I need this charger working so I can do some testing/logging on the 22S AMP20 batteries before I build them into a pack.
RC_guy   10 W
Post by RC_guy » Jun 23 2014 12:35pm
Hi guys,
I made a new topic with the post below. On 2 of my chargers, the inputs seem to have shorted but I cannot find anything that is burnt??
Hi guys,
I have been charging lipos for 8 years now. Except 3 years ago I started charging 12S 15ah packs from a Thunder 1220 charger. This was a 300W 14S capable charger. I liked I could charge my 12S pack without any modifications.
The input shorted??? I tried turning it on one day and my power supply would not turn on (ATX 12V PSU). I tried with a 12V battery and the 30amp input fuse on the input side of the board blew. I replaced it and tried the charger again.
After about 5 seconds of the charger being ON with no load, the fuse blew again.
Just over a year ago I got a Hyperion 1420i which is 550W and also 14S capable. I was powering that one with 2 atx psu in series and I cut the gnd wire to one of them.
A week ago it did the same thing. Except this one has a 40amp input fuse that did not pop but my psu would not turn on. And connecting to a 18V battery (to turn the charger ON with no charging load) I almost melted the bullet connector.
This charger is capable of 28V input.
I just ordered a Thunder Power 1430C and I hope this is the last one I need to buy?!?
Could this be due to my psus?
Could it just be that those chargers don't like charging 12S?
They do get quite hot for over 1 hour when I charge.
Could they be repaired?
Thanks in advance!!
runnjarn   1 µW
Post by runnjarn » Jun 27 2014 5:15pm
Hi!
Very useful information in this thread.
I never heard of problem with this charger before. Maybe because I haven't had any problem myself.
I have two units bought back in 2011 that just works, I charge everything from indoor 2s250mAh to 14s5000 packs at maximum power.
But as I found out that they were discontinued, I started to scan all webshops to be able to get one as backup in case of failure.
I found at last unit in a shop in Germany.
I started to use that charger for an electric scooter, having a 7s8700mAh LiPo (my own conversion, was 24V 10Ah lead)
After just a few days of use, less than 10 charge cycles, the charger just popped and emitted white smoke when starting a charge cycle.
I use a Wellpower 27V/37A supply for my two old and still working chargers.
For my new and fried one :cry: I used a 13,8V/20A supply.
I charged the 7s with 6A, meaning a 176 W output at max.
Don't know what efficiency the charger have at 13,8 V in and 29 V out but maybe I've been on the limit for the power supply and
had voltage drop leading to relatively high currents in the boost conversion circuitry?
Anyone that know if stressing the unit with low input voltage make it more prone to failure?
Deanwvu   100 W
Post by Deanwvu » Aug 17 2014 9:13pm
rkosiorek wrote:Here is a simple schematic how to wire up the 12S pack to the PortA abd PortB connectors
1420i-12s Balancer by rick_kosiorek, on Flickr
worked fine for me.
rick
On the charger, which pin is #1?? The left most pin or the right most?
http://www.endless-sphere.com/forums/vi ... 28&t=70368 My Big Dummy drive by LightningRods.
Deanwvu   100 W
Post by Deanwvu » Aug 19 2014 2:59pm
No one knows?? I'd hate to wire up the 16 balance leads only to find out that I wired them backwards!!
schwibsi   1 kW
Post by schwibsi » Sep 25 2014 4:58pm
I have a 1420i that behaves strangely.
It charges a 13s pack (without balancer connected) just fine, but it doesn't recognize a 10s that I have.
Does anybody have a circuit diagram that I could use to check what's wrong?
wesnewell   100 GW
Post by wesnewell » Sep 26 2014 12:46am
The low side of the balance ports is on the right side. That would be cell 1 or 0 if you you prefer to start from 0.
stonezone   100 W
Post by stonezone » Sep 30 2014 2:27pm
my thermister fried yesterday charging a 12s 30000mAh at 20A.... ordered replacement, hope it works. Fan on it died a while back so have been using an external fan but somehow it got super hot.... any ideas why, or just cheap chinese parts?
LR-BB on 2014 Glory
Sur-Ron
B B S-HD on some sort of DH Kona frame
2017 GG GP 300 <3
RIP Bobarella
dnmun   100 GW
Post by dnmun » Sep 30 2014 5:51pm
you can buy replacement fans on ebay. failures of the ICL is really common on some chargers. i have been selling 18mm, 6.3A, 5 ohm replacements for few years now.
stonezone   100 W
Post by stonezone » Oct 01 2014 5:01pm
yeah i ordered a 4 pack for $10 on eBay... would have got them from you if i'd known :)
LR-BB on 2014 Glory
Sur-Ron
2017 GG GP 300 <3
RIP Bobarella
dnmun   100 GW
Post by dnmun » Oct 01 2014 6:02pm
try to replace the fan so you have maximum air flow over the ICL. the fan exhausts air from inside the case, and draws it into the case directly over the ICL to keep it cool.
when you install the new one, make sure it is standing on top of the legs and not on the surface like a resistor and push it out into open space there so it is not touching anything else so when it gets hot it doesn't damage anything.
hot is what they do for a living. i think this is the most common or systemic failure of all these SMPS chargers. the ICLs sold and used in these is made in china, and the quality control for a difficult to make device is low in these plants imo.
stonezone   100 W
Post by stonezone » Oct 04 2014 1:50pm
the fan itself works but wasn't getting power. I used a much larger fan from a server that was (I'm pretty dam sure) keeping it cooler than the stock fan. I ran it for a couple of months until this... we'll see when my parts arrive....
LR-BB on 2014 Glory
Sur-Ron
2017 GG GP 300 <3
RIP Bobarella
dnmun   100 GW
Post by dnmun » Oct 04 2014 2:11pm
no power to the fan could be a bad transistor on the fan control power source. usually the fan has a 100 ohm resistor in line with the collector of the npn transistor that is turned on by the op amp that drives it. or the thermistor input on the other side of the input of the op amp could be missing.
mistercrash   10 kW
Post by mistercrash » Mar 23 2015 2:07pm
"OUTPUT VOLTAGE TOO HIGH" error trying to charge some smaller lipos. I can still charge a 7S battery no problem. I saw a couple who had a similar problem. Any of them actually did the repair?
Send $10 at paypal.me/Ray1964 and you will be in my thoughts and prayers.
mistercrash   10 kW
Post by mistercrash » Mar 24 2015 2:03pm
I found out why my 1420i was displaying "OUTPUT VOLTAGE TOO HIGH" and would not charge 2S lipos or NiMH batteries. I remember one day, I had my charger plugged into its power supply which was plugged into the same wall outlet as a small drill press next to the charger. I remember the main power leads of the charger touching the metal table of the drill press and made a spark. I didn't think much of it at the time except for putting the charger in a different spot but that is when the error message started. When the charger shorted on the metal table, it blew a MOSFET. From then the charger would display the error message anytime I wanted to charge a battery that had less voltage than the power supply (12V). I found which MOSFET shorted and changed it to a new IRF4905 and now the charger will charge anything I throw at it. Problem resolved.
Ratking   1 kW
Post by Ratking » Apr 14 2015 2:57pm
Hello
I took a few pictures of my charger, because I really miss it and want to repair it if possible.
My bike with LiPo needs to be balanced since I discharge the pack at its limits.
Do anyone know how to start diagnose from the pictures?
neptronix   100 GW
Post by neptronix » May 25 2015 8:57pm
After ~3 years of irregular use ( maybe 400 charges overall ), one day i wake up after a 3 week bike riding lull and get 'output battery connect error' :(
The 1420i properly detects the battery voltage before i hold the button down to start the bulk charge..
I have checked my connectors.. no problems with them that i can see :/
I suppose it's dead. But i'm really disappointed because i never abused this charger at all, ever.
dnmun   100 GW
Post by dnmun » May 26 2015 12:28am
look for the mosfet on the output. if it is burned open then your charger would not see the connection to the battery. or there may be a bad connection inside on one of the leads.
dnmun   100 GW
Post by dnmun » Jun 04 2015 7:06am
ratking asked me about his charger. first we need to know how and when it failed, can you measure voltages coming into the charger from the power supply? is the fuse open circuit? do you know how to test the mosfets to see if they are functional?
Ratking   1 kW
Post by Ratking » Jun 04 2015 10:35am
dnmun wrote:ratking asked me about his charger. first we need to know how and when it failed, can you measure voltages coming into the charger from the power supply? is the fuse open circuit? do you know how to test the mosfets to see if they are functional?
The fuse is intact, I have not seen any burnt or damaged components, and that is as far as I have come in the troubleshooting process. I don't have the charger where I am right now, but I will tomorrow. I have not checked mosfets before, but I can read a bit and learn how to do it. Do you know what the different fets do? Could you point me in the right direction on one of the pictures I posted?
Thank you
dnmun   100 GW
Post by dnmun » Jun 04 2015 11:06am
have you ever repaired anything before? do you know what a transistor is? your pictures are not useful, just too big for the page. you should always use VGA settings for pictures here. most of them at 4110 n-channel mosfets and the 4905 is a p-channel mosfet.
neptronix   100 GW
Post by neptronix » Jun 04 2015 1:00pm
I have looked over the board with a fine tooth comb.
No components look off at all.
Just dead on the inside, like a goth kid..
