Johnbear
TECHNICAL SEPCIFICATION
Dimension: Height 43 mm, Diameter 23 mm
Weight: 57g
Capacity: 4500 mAh
Voltage: 1.2V
Standard Charge: 15 hours @ 300 mA
Rapid Charge: 2 hours @ 3000 mA
30 cells at 57.g is 1.71 kg
90 cells 13.5 ah 5.130 kg (11 lbs)
Has anyone tried these cells. Seems to good to be true. http://cgi.ebay.ca/12-Pcs-of-Matched-Sub-C-4500mAh-NiMH-Battery-with-Tabs_W0QQitemZ330161139031QQihZ014QQcategoryZ34063QQtcZphotoQQcmdZViewItem
Weight: 57g
Capacity: 4500 mAh
Voltage: 1.2V
