Homemade Battery Packs
ASK1   10 mW
Re: Homemade Battery Packs
Post by ASK1 » May 09 2015 11:04pm
DrkAngel wrote:Current equalization is helped by providing extra heavy wire on the end "rails".
See = Cell interconnections for cans - ES Wiki
Alternate method for true equalization...
What exactly do you mean by end rails? I'm not familiar with the terminology. It's basically the 2 parallel rails on the end that actually lead directly to the positive and negative terminals? Can you explain why having more conductor there would help, my (probably wrong) intuition would be that any smaller rail in the pack would act as a bottle-neck.
As far my parallel rail conductors: I'm using fairly heavy wire on the whole pack - tinned copper braid similar to what I see in your pack here:
Does using a high-enough capacity conductor (like this copper braid) basically eliminate the electrical path length concerns?
I could wire it as you suggest, but my hope is to keep all the major connections on one side (which would be the top side of the pack) for housekeeping & various other reasons[/quote]
DrkAngel   100 GW
Post by DrkAngel » May 10 2015 5:55am
It appears you are building parallels first, then running in series using a single connection. ... ?
I, personally prefer to build in series first, so there would be 8 low current series connections, evenly distributed current.
Then I run parallels, creating redundancy and equalization functions ... lighter gauge wires required.
Full current is then combined and collected into the high capacity, heavier gauge, "end" power rails. (Of gauge substantial enough and short enough to minimize voltage drop as a factor )
UL rating is:
14ga = 15A
12ga = 20A
10ga = 30A
8ga = 50A
I tend to double the UL rating for maximum surge-brief throughput and consider line drop as a negligible factor.
14ga = 30A
12ga = 40A
10ga = 60A
8ga = 100A
7s10p 18650 diagrammed - 25.9V 26Ah (w/2600mAh cells)
The tinned copper braid I use weighs more than 3 strands of 12ga copper and should be good for 100A, so is overkill on my 40A fused pack.
Oh yeah! Don't forget to add a fuse to your pack! Could save you a whole lot of heart ache!!!
You could easily up your equalization factor with dual series connections ... ? Or attach in center of parallel ... ?
Output connections will be 13s apart!
My typical method would have 8 series connections.
As mention in the Wiki article, I tend to build in parallel 1st for large bulk packs only and would use multiple series leads ... providing redundancy, equalization and the necessity for lighter gauge, easier to work and safer to solder to cells, wire.
Index - Homemade Battery Packs - Updated - December 2019
EBike Toolbox - Bargains! $
Endless Sphere Wiki - Lost?
ASK1   10 mW
Post by ASK1 » May 10 2015 4:01pm
I can't really change the circuit configuration, I already have a 13S BMS and the design of the 8P group prevents them from having connections besides the end-connections at cells 1 and 8.
I will try to do it as you have suggested. Thanks for the advice.
Skalabala   1 kW
Post by Skalabala » May 15 2015 9:12am
Could this be of any help to test cells with?
http://alienpowersystem.com/shop/electr ... ontroller/
Boosted cars are like hot women. A little edgy, every guy wants one, some guys can't handle them, and if you throw a little alcohol in them they'll rock your world! Born a Jap raised as a boer!
jaunty   1 W
1 W
Post by jaunty » May 15 2015 12:30pm
maybe a silly question here but...
I need a 48V battery. I want to build in series, but not one entire string of 13S. maybe one 6S pack and 1 7S pack.
if 48V requires 13S..how many in series is required for 24 systems? certainly not 6.5S (unless youre a badass).
I'd like to segment the pack into two 24V packs.. then wire those in series. But what problems does that pose for BMS?
Thanks
riba2233   1 MW
Post by riba2233 » May 15 2015 2:43pm
Actually 14S is better match for 48V, and 7S is great for 24V. There should be no problems for two bms in series.
My electric moped: http://www.evalbum.com/4966
My electric car: http://www.evalbum.com/5364
jaunty   1 W
1 W
Post by jaunty » May 15 2015 7:18pm
i have a lot of sanyo 18650 (red ones from lenovo thinkpad) and im finding that most of them only charge to about 3.9-4.1 volts. most in the 3.95 range.
either thats their max voltage, or im not leaving them on the charger long enough. Basically because im paranoid and i dont want to overcharge them.
anyone have input on this?
parabellum   10 MW
Post by parabellum » May 15 2015 10:16pm
riba2233 wrote:Actually 14S is better match for 48V, and 7S is great for 24V. There should be no problems for two bms in series.
There can be a problem actually.
1) If they have separate charge/discharge leads (describe the processes )
2)If charge/discharge are together, what happens when charged one shuts down first (repeatedly)
parabellum   10 MW
Post by parabellum » May 15 2015 10:20pm
jaunty wrote:i have a lot of sanyo 18650 (red ones from lenovo thinkpad) and im finding that most of them only charge to about 3.9-4.1 volts. most in the 3.95 range.
Yes, charge to 4.2V whatever it takes attended, use cc cv method and come back. :)
riba2233   1 MW
Post by riba2233 » May 16 2015 3:12am
I don't get it, just wire bms for each half of pack, and then wire packs in series?
DrkAngel   100 GW
Post by DrkAngel » May 16 2015 6:38am
Build 2 identical 7s packs each with it's own BMS. (Confirm controller compatibility? 58.8V)
Rig the 2 packs in series for use.
Confirm electrical isolation between chargers - if 2 separate chargers used, (1 to each pack), still in series, at same time.
Single full voltage charger through 2 BMS'ed packs in series ... of unknown recommendability. (Dependent on BMS functions - quality)
jaunty   1 W
1 W
Post by jaunty » May 16 2015 3:13pm
I bought some of these...
Anybody have any bad information about these? all but one contained the sanyo 2600 mah. red ones. I think they're pretty crappy so far considering i paid a buck a piece.
They dont reach 4.1.. they heat up at 4V, then those ones that heated up end up resting at 3.85'ish.
hmmm.
picture uploading
Allex   1 GW
1 GW
Post by Allex » May 16 2015 3:17pm
I would not even use those for my flashlight :)
Not to mention high current ebikes
tomjasz   10 GW
Post by tomjasz » May 16 2015 3:57pm
jaunty wrote:[img=http://s5.postimg.org/n76xm7igj/lenovo.jpg]
hmmm.
I made some packs for my 24V scooter with them but if you're getting heat and they're all mismatched...well, not good. Group them by output if you must. It's a fun project just be mindful of the heat and have low expectations. It is fun... I ran mine through all sorts of charging and discharging cycles and used what was left for solder practice. It's a lot of work to build a pack and get shutdown by a couple of crap cells. But again, it's a good learning platform for the day you can build with a decent set of batteries.
jaunty   1 W
1 W
Post by jaunty » May 16 2015 4:00pm
[/quote]I made some packs for my 24V scooter with them but if you're getting heat and they're all mismatched...well, not good. Group them by output if you must. It's a fun project just be mindful of the heat and have low expectations. It is fun... I ran mine through all sorts of charging and discharging cycles and used what was left for solder practice. It's a lot of work to build a pack and get shutdown by a couple of crap cells. But again, it's a good learning platform for the day you can build with a decent set of batteries.[/quote]
yeah im just here for fun really. the learning experience. I'm looking for a good pack to buy, then i can continue collecting cells for a build. The prices for parts for building just seems really high. Those ebay guys think their shit is worth gold!
tomjasz   10 GW
Post by tomjasz » May 16 2015 4:51pm
By the time you build a pack of the quality you see priced you'll realize that battery packs, that are of high quality, are worth the dollars. At least I've found that. Building a quality pack with a decent BMS and cells is pricey. Period.
DrkAngel   100 GW
44.4V Advantages
Post by DrkAngel » May 17 2015 8:44am
You might want to consider a 12s 44.4V pack.
More symmetrical, compatible and much easier! ... ?
Inexpensive 6s chargers and balancers ... 12s BMS's and chargers etc. readily available!
Especially with a 36-48V compatible controller.
(Standard 48V controller might LVC cut-off too high ... but would prolong actual usable lifespan)
DrkAngel   100 GW
To BMS or Not to BMS?
Post by DrkAngel » May 17 2015 10:14am
With properly tested, matched and monitored cells ...
A BMS becomes more an expensive security blanket than a necessity.
Test cells
1. Eliminate self discharging cells!
Charge cells to rated or anticipated charge voltage
Let set idle for several days and monitor for and eliminate all with a notable self discharge
(I bulk charge large numbers in parallel, then separate to diagnose self discharge)
2. Test IR (Internal Resistance)
An IR meter is rather expensive ...
So I run a comparative IR test
With cells still of equal voltage, apply a measured drain to each cell or pair of cells etc.
Monitor voltage sag with the specific discharge amperage for a specific time
EG 1A or .5C for 1 minute ... ?
Label each cell or pair with the sag voltage for use as it's comparative IR (-.12V)
Cells with excessive IR should be eliminated, or separated for alternate use-project.
3. Test Capacity
Cells can be capacity tested individually
a. But I prefer to do a time and effort saving bulk capacity test
(Use self discharge and IR tests will eliminate most low capacity cells 1st)
I rig 28-30 cells, (typically paired cells = 56-60), in series for a 117.6-126VDC .
Then I attach 2 - 60w (120w) light bulbs for a 1Amp discharge. (1 - 60w for .5A discharge etc.)
(Quick check for any "bad" IR cells I might have missed)
Check-monitor voltages of every cell at specific intervals, 15min = .25Ah, 6min = .1Ah etc.
Monitor very closely as cells near 3.60V, as voltage will drop suddenly near that voltage!
You can end test when first cell hits 3.50V and label each cell with time expired (2 hours = 2000mAh) and residual voltage after discharge removed.
This will give you a reasonably accurate comparative capacity.
or
You can further, more accurately, test capacity by continuing test with matched cells from subsequent batches of cells.
b. I combine 20 cells (or cell pairs = 40 etc.) in series and discharge through a cheap 90V V-A-W-Ah meter - $12 (requires external battery connected for maintaining mAh reading when cells removed)
Add electrical discharge devices till desired discharge rate attained (2-3 bulb light fixture, various wattages - 50-100-150w 3-way bulb?)
As cells hit discharge voltage ( 3.50V?) remove cells and mark with mAh when cells removed from series.
(For ease, I, now, connect cells in series with small 8mm neodymium magnets, steel wire on end of strings to fold into shorter stings)
(Recharge all cells to identical voltage)
Match cells
Build banks of equal capacity.
If IR varies noticeably and short of spare cells, distribute a similar sampling of differing IR cells to each bank.
Connect cells in series and parallel and perform a monitored discharge at near anticipated use.
Monitor banks for any sags or low final voltage.
If banks of equal voltages during deep discharge (3.50V?) and after discharge removed, pack is of equal capacity and IR.
Banks of equal voltage after deep discharge (~3.70V?) indicates banks of equal capacity.
If unequal, rated cells can be swapped to equalize.
If' when drain removed, bank voltages diverge, then IR can be adjusted by replacing individual cells with ones of higher or lower comparative IR.
Building banks of equal capacity and IR is more important than individual cells!
It may seem like a lot of effort!
But after many, many builds and 10s of thousands of eBike miles ...
Building it right to begin with saves much time and effort!!!
Banks of equal capacity and IR will discharge and recharge nicely to nearly identical voltages!
Bulk charging recommended with the occasional or scheduled balance charge.
Do monitor charged and discharged voltages for any problem or to determine when balance charge desirable.
Summation!
Remove self discharging cells
Build banks of equal capacity and IR
Never over charge or discharge
Monitor bank voltages
Never need or want a BMS ... !
I have come to view a BMS as a band-aid for a defective pack!
See - Bulk Capacity Testing
Oh!
Designed tests for recycled cells ... but
Test new cells too!
If nothing else ... test for self discharge! and demand replacements for these defective-dangerous cells!!!
jaunty   1 W
1 W
Post by jaunty » May 17 2015 11:07am
thanks Drk..
my inclination is that a 48V motor should be operated as close to 48V as possible, in which case the 12S or 13S makes most sense. But i havent performed any tests. What would the drop be (sag?) during riding of a 14s, 13s vs 12s pack?
so i crafted this table up right quick.
windows screenshot
would these numbers also drop by a bit due to load? That would be the only argument i could see for running a 14S pack. Or is some other benefit?
riba2233   1 MW
Post by riba2233 » May 17 2015 1:22pm
Yeah, you will see big drop with used cells, so go with 14S.
BMS might not be necessary, but it's hard to always take care not to overcharge and over-discharge, so it's good thing to have, and it only costs 20-30 bucks, but it can save whole pack.
jaunty   1 W
1 W
Post by jaunty » May 17 2015 2:00pm
yeah.. i found a BMS from aliexpress for around $23. So i figure i'll play with that.
DrkAngel   100 GW
Post by DrkAngel » May 17 2015 2:06pm
LVC on a 48V controller is typically ~41V.
Which makes 12s seem feasible ... especially if bank 13 and 14 have their cells added to the 12s.
14s10p will sag more volts than 12s12p, ... but not to a lower voltage.
But check your 48V controller for 14s (58.8V) compatibility. Many have a HVC!
With any pack build ... Add a fuse!!!
Can save you from a whole lot of heartache!
jaunty   1 W
1 W
Post by jaunty » May 22 2015 7:33pm
Allex wrote:I would not even use those for my flashlight :)
actually, if you dont me asking. Why not?
Inside are the UR18650F sanyo cells. Are those bad news?
Cheers
DrkAngel   100 GW
Self-discharge
Post by DrkAngel » May 23 2015 7:57am
Cells that "heat up" have internal shorts = severe self-discharge.
Unreasonably hazardous to use ... worse when combined!
Best used for "end of life experimentation" ... borrow Ypedal's fire suit?
(They should accept "full" charge, briefly, if extreme current applied = fire-explosion danger! )
jaunty   1 W
1 W
Post by jaunty » May 23 2015 1:28pm
Yeah. I mean these particular cells in general.
All the cells that heated up at all I marked and put aside. None of them heated substantially though (could still hold in my hand them easily) But then later i went to charge them and they charged right up without any heat. I'm not sure why that is the case. I believe these are protected cells though, so too high of voltage charge may have caused that.
I finally charged all 60 cells and now time to discharge them all and make plots! I have a nifty rs232 program. I should have bought two of these multimeters so monitor current and voltage simultaneously.
Thanks for all your posts Drk they are very helpful.
