Using DIN Rail Power Supplies as Meanwell Current Limiting
icecube57   1 GW
1 GW
Post by icecube57 » Jun 08 2011 5:39pm
I was cruising through ebay. I was wonder has anyone ever thought about using the small DIN Rail power supplies as chargers or as external current limiting devices.
http://cgi.ebay.com/120W-Din-Rail-Mount ... 41574f34a1
http://cgi.ebay.com/New-75W-Din-Rail-Mo ... 3f07c7684f
They are adjustable and feature constant current limiting. Put it in series with your supply and you have a current limited charger with no modifications to the supply.
xiteamxi   100 mW
Re: Using DIN Rail Power Supplies as Meanwell Current Limiting
Post by xiteamxi » Mar 11 2018 10:42am
"Protection type: Constant current limiting, recovers automatically after fault condition is removed"
sounds to me it just shuts down if to much current is pulled and resets when current drops to an acceptable valve. would be ideal if it really functioned with CC if you try one let us know or if any one can confirm they do have a constant current function please chime in.
flippy   10 kW
Post by flippy » Mar 12 2018 10:41am
these are NOT constant current. they will simply shut down.
Lithium beats liquid dinosaurs.
