One thing about paralelling packs. If you are using the typical 6s or 8s charger, it doesn't balance very fast on the now larger pack. I don't know about the hyperion, but on the cheap chargers the balancing function is not sized for working with packs that size, such as 10 ah. So it can take a really long time to balance a pack that is more than .02 out of balance.
I've been doing it like this, I have permanently paralelled two packs together at the main wires. But not at the balance wires. About every 10 cycles or so, I'll balance charge them. Before I hook up a y connector to paralell the balance wires, I look at the voltage. If pretty close, say within .1v I connect and balance charge them. If way off, then I hook a small B6 charger to just the one low cell in one pack and bring it up closer before plugging in the jst's to the paralell harness.
You can just leave the y connecting harness in place if you like, but the point I am trying to make is that if you permanently connect the balance wires, you can no longer look at the voltage of an individual cell. I've had one cell in a 2p 5s pack go bad. So I remove the bad pack, and retain the still good one. Hard to tell which is which once you solder the balance wires paralell.
