(edit: originally this was a wanted thread, but is moved to save the discussion bits)
I'm looking for BMS boards to support 10-15 LiPo cells, and as long as the PCBs are not actually burned to unusability, I could repair blown FETs, etc. If they're MCU-based BMS boards, I'd need the MCU part to be working, but I could replace most any other component with parts out of my other junk laying around here.
I can afford almost nothing for payment (seriously, I shouldn't even be considering this right now but need more range and to lighten the bike from my SLAs), so if you have one you were going to throw away anyway, or is sitting around in that fried battery pack you're never going to do anything with, I could pay postage and maybe a bit more (to Phoenix, AZ, USA, 85051).
I'm going to attempt to build packs for my CrazyBike2 out of individual LiPo cells, and I think it'd be a lot safer if I had BMS boards for every set to ensure HVC and LVC protection, given the reputation LiPo cells have for "celebratory lightshows" when those are exceeded.
I'll probably start with 36V nominal packs, preferably with each individual series set having it's own BMS, then parallel all those packs together to get the current needed to run the bike. I might end up wanting to use 48V packs by the time I'm done, but it runs fine on 36V now, and would require regearing anyway if I went to 48V to keep the total max motor speed at 20MPH.
So for those willing to help out, post here what you have and what you want for it and we'll figure it out from there.
