drutledge
I just tried to hook up some newly shipped (from Hobby King) Zippy 6s 5000mah lipos in series using a series harness from EP Buddy. Both batteries were at about 53% as shipped and cells were balanced separately, then together before hooked up. The EP Buddy harness is pretty much idiot proof but I got a very good spark when I made the last connection, the all red jumper wire. Spark was good enough that I now cannot get a good female onto the sparked male, nor the sparked female onto a good male. Both are black on the inside though the plastic is not melted; I jumped and the connection did not stay together.
One possibly very important note: I had the balance plugs wired in together in parallel using another harness. Was this a big no-no? I've seen many packs on this site, mainly 12s2p (my final goal here) where all four batteries' balance leads were wired together in parallel. My thought was if one can do that then the balance leads from any one battery can be paralleled with any other battery's in the 12s2p pack. Wrong assumption?
Both batteries seem fine; still balanced, same voltages as before, etc. The series harness might be best replaced though...
