Accurate affordable RI meter for low impedance cells?
Degull   100 W
Re: Accurate affordable RI meter for low impedance cells?
Post by Degull » Nov 29 2011 3:41pm
For those of us that are electronically and mathematically challenged, some clarification please. I've been quietly reading and fumbling along with this thread. Still not sure how I would set myself up to do this correctly.
What would you use as a load to get a 20-30 amp current draw? Someone mentioned a precision resistor with 00 gauge wire, would this be the load? If so what value precision resistor would you use as load to get 20 or 30 amps?
I would like to play around with this but I'm still muddy with how to set it up. For example, If I had a A123 2.3ah cell, what value precision resistor would you use? What if you had a A123 20ah battery what values would you use?
I have a decent DMM. If that along with a resistor is all I need, then this would be easy to troubleshoot my own batteries.
parabellum   10 MW
Post by parabellum » Nov 29 2011 7:53pm
This one costs 30U$ and is pretty constant on values, but see no way to check how accurate it is.
http://endless-sphere.com/forums/viewto ... 14&t=34154
Degull   100 W
Post by Degull » Nov 29 2011 8:39pm
parabellum wrote:This one costs 30U$ and is pretty constant on values, but see no way to check how accurate it is.
That's why I like to the idea of using a resistor and a Multimeter. I don't have to buy another piece of gear and I can rely on the readings I take with my Multimeter.
parabellum   10 MW
Post by parabellum » Nov 29 2011 10:41pm
I want see how you measure IR under 1kHz frequency with resistor. :)
Edit: It is stated 5% accurate. If it is truth, it is enough for me.
