Construction pics of an xtracycle's LifePO4 pack
oatnet   10 MW
Post by oatnet » May 07 2008 12:41am
Here are some pics of building the battery packs I built for the xtracycle. The "Freeloaders", as the xtra folks call the bags on the sides, have two sections. The bulk of cargo carrying capacity comes from the ballooney part of the back, but there is also a flat pocket that runs much of the length of the freeloader. I had these batteries in nicely configured bricks, but when I inserted them in this pocket they came in contact with the wheel. If I ifilled the pocket with a 1/4" plywood board it stopped the ballooning, but there wasn't enough room for the battery. Carrying the battery in the outer balloon pocket was too exposed, and not stealthy.
I realized that the 1" thick batteries would fit in the pocket if laid in a flat layer, the 1/4" plywood board could prevent bulge, protect the cells from road debris, and be a mounting platform.
I decided to connect the batteries with 1" copper strip I bought on ebay. Flat strip supplys maximum contact wtih flat screw terminals, and is also a structural element in my pack.
Phase 1: Making plates to connect the cells flat copper strip to get maximum conductivity to match the flat screw terminals.
01_IMG_3991 drilling.jpg (80.92 KiB) Viewed 2506 times
I made a template of a connecting plate, traced it onto the copper strip, and drilled it out.
02_IMG_3992 strip done.jpg (140.48 KiB) Viewed 1426 times
Out of 50' of copper strip, this was all I needed.
03_IMG_3995 cut and flattened.jpg (45 KiB) Viewed 2501 times
The strips have been cut with metal shears, tapered at the ends to hold heatshrink, and pounded flat with a mallet while between two pieces of iron,
04_IMG_4004 chargin lead soldered.jpg (63.37 KiB) Viewed 2492 times
I cut leads for the charger to appropriately staggered length and then soldered them to the copper plate.
Shrinkrwap around copper plate. I cut out holes for the battery contacts and trim the ends to just fit. This provides strain relief for the charging lead and if the solder fails it will stay in place. I also like to minimize contact points so jacketing the plate makes it a little safer if someone jams a screwdriver in there.
06_IMG_4008_ holes cut.jpg (68.27 KiB) Viewed 2480 times
A stack of plates ready to be installed.
07_IMG_4010_completed harness.jpg (33.76 KiB) Viewed 2736 times
Here is a completed wiring harness. I build it on the battery, and then heat shrink each charging lead in turn, ending up with a fairly rigid backbone. I built the harness on batteries but had to remove it and mount them the other way, hence this shot.
oatnet   10 MW
Re: xtracycle LifePO4 pack
Post by oatnet » May 07 2008 12:57am
08_IMG_4014_mounting board.jpg (63.96 KiB) Viewed 2462 times
The strip of wood up the center to act as a stiffener, protects the wiring harnesses, and it has a hole cut in it to thread a cable lock through. Also notice the holes drilled in the board for the wire ties. I later add large finger holes in each corner to make it easier to get in and out.
09_IMG_4015_batts in place.jpg (57.64 KiB) Viewed 2460 times
Here are the batteries laid out the way they are going to be mounted.
10_IMG_4034. oops.jpg (85.8 KiB) Viewed 2458 times
...and while using my heat gun on the final bit of shrinkwrap on charging harness, I melted the jacket on at least two of the wires, causing a short and a plasma ball that melted ALL of the charging wires and caused a bigger short until I clipped wires. One instant I was pushing the batteriens back against the wood, the next thing I knew there was an explosion of smoke. I thought one of the cells had gotten overheated and was ready to blow, LiCo style!
I originally intended to shrinkwrap these cells to the board. That probably would have worked well, although it is fairly permanent, not maintenance-friendly. Thanks to folks here, I found shrinkrwrap big enough, and I even mighta coughed up $35/foot for it... but not for a 25' roll of it, minimum order. Instead, zip ties are also non-conductive, light, strong, cheap, and easily replaceable for maintenance. I use one set of wire ties to wrap around the copper connector plates, holding each cell's terminals firmly against the center wood strip, preventing motion. I cut groove through the center strip so the wire ties are less exposed. The second string of zip ties holds the body of the battery to the boarrd, and also maintains some spacing between the cells to keep them cool. Also note the security hole cut in the center strip for running a tether.
Here is the back of the board, showing the wire tie pattern.
13_IMG_4036 both.jpg (101.5 KiB) Viewed 2449 times
And finally, the two 36v packs assembled and ready to give my xtra 88.8v!
oatnet   10 MW
Post by oatnet » May 07 2008 1:02am
14_IMG_4024 next to xtracycle.jpg (71.06 KiB) Viewed 2443 times
One of the packs next to the xtracycle for scale.
15_IMG_4025I inserted in pocket to strut.jpg (52.28 KiB) Viewed 2442 times
The pack is halfway inserted here. The center strip is taught against the pocket, making a tent that shields the charging harness from contact.
16_IMG_4026 Fully inserted.jpg (73.45 KiB) Viewed 2434 times
The pack is fully inserted into the pocket. The flap sits above the pocket, giving me just enough clearance...
17_IMG_4029 stealth.jpg (85.91 KiB) Viewed 2436 times
And finally, with the pocket closed. I need to take another picture with the velcro fully sealed and the charging harness concealed. As you can see, there is no way to tell there is a battery in the side pocket, even the hubmotor is concealed, making this the perfect stealth cycle. Plus it is flexibile enough to carry 6 bags of groceries and/or a human via the dedicated footpedals.
The packs ended up being just over 15lbs each, and the free radical keeps them stable and close to center of gravity. Although VERY convenient, I won't do another external charging harness, now that I have seen what can happen when you get a short in one...
I have found that with the weight of the batteries and the hubmotor, even standing still I can sway the mass back and forth - the bike is solid, but the hookworms are flexing! In addition, wiith all the weight in the rear my steering input on the front is more of a suggestion than an directive. Still, it tracks a true line and the long wheelbase helps at higher speeds.
Member 117 of 26,000+
153v DUNE BUGGY © 164v Vectrix E-Moto © 72v Norco A-line/x5403 © 60v Specialized Enduro Comp/BMC © 72v x5tracycle © 48v TF IO/BMC © 36v Kepler FrictionDrive © Spot-Welding a123 © Pelican Front Packs © Vectrix Battery Replacement © MORE !!
Image大鸡巴 Motors
Knowledge is acquired through experience, everything else is just information - Albert Einstein
"Cheater?" I'm not competing, I'm Commuting!
kyakdiver   100 W
Re: Construction pics of an xtracycle's LifePO4 pack
Post by kyakdiver » May 07 2008 8:37am
Oatnet,
Very nice job with the packs! I do have a soft spot for the Xtracycle and I think I'm going to try and do something like this with my Duct Tape packs.
Keep up the good work!!
Kyakdiver
Specialized Sirrus Pro Disc 700 Hybrid Xtracycle equipped
BMC Geared Hub from EV Tech
36-72V 40A Controller
48V x 10Ah x 2 parallel Lifepo4
2000 miles and counting
Roonster   1 mW
Post by Roonster » May 07 2008 11:08pm
Hi Oatnet,
Really love your bike, looks like it came together in a great package.. Ever since seeing it I've been keeping my eye open for an Xtracycle I'd like to add one to my bike one of these days.
Where did you get the cells you are using? What are you using for a BMS and for charging?
Sincerely,
Roonster
Dee Jay   100 kW
Post by Dee Jay » May 07 2008 11:39pm
Wowee! Good stuff there oatnet... very neat design and thoughtful construction techniques.
So where do you park your bike again?? What's the location of your workplace? And do you have a anti theft device we should know about? RFID tracking device? Pager alarm? Just kidding! Keep it safe!
So many good builds on ES that I haven't commented on! Keep up the quality work everyone. 8)
J
oatnet   10 MW
Post by oatnet » May 07 2008 11:52pm
Roonster wrote:Really love your bike, looks like it came together in a great package.. Ever since seeing it I've been keeping my eye open for an Xtracycle I'd like to add one to my bike one of these days.
Greetings Roonster,
Thanks!
I got the cells from Andy at FalconEV.com last October:
http://endless-sphere.com/forums/viewto ... =14&t=2503
Haven't looked at that link in a while - I documented "496 g (1 lb 1.5oz) on my kitchen scale", so 12 cells should weigh 13+lbs. Since the pack weighs in at 15+lbs, the entire packaging and mounting for pack, including the long (foolish) charging harness and wood panel, is only about 2lbs. Not bad!
I put many cycles through them in the old "brick" configuration - and hopefully many more cycles in the future. They came with the "Flintstone" chargers (do a search) which balance on charge, no discharge BMS but I rarely go below 70% DOD anyhow, to extend cell life.
-JD
Image大鸡巴 Motors
oatnet   10 MW
Post by oatnet » May 08 2008 12:04am
Dee Jay wrote:Wowee! Good stuff there oatnet... very neat design and thoughtful construction techniques.
J
:D Thanks Dee Jay!
Image大鸡巴 Motors
