dogman said:So the cells in the 20 ah boxes are thundersky? I wasn't sure what brand of cell there was in there. They say GBS, whatever that is.
Rin said:I have a 48v20ah Elite battery, they are GBS cells. They are not the same manufacturer as Thundersky, at least as far as I know. I have a 9c 2806 motor. I have had the battery a little over a year. The biggest problem is the batteries sag quite a bit. There is no BMS, just cell balancers which bleed the battery after reaching 3.7 v. I have a cycle analyst to watch for low voltage otherwise there is no way to keep a check on low voltage. When the batteries were new I was getting slightly over 1000 watts output, now about 950 watts according to the cycle analyst. It is a fairly heavy battery for Life4, although manageable.
frodus said:"THEY" don't screw you, UPS/Fedex does because they ship Hazmat Class 9 because they're a company within the US. Not really their fault IMHO. Chinese companies cheat and don't really follow legal shipping procedures, thus, cheaper shipping.
Ypedal said:And the reason the shipment should be declared DG is not to add care in handling to the package.. it's to protect the workers in the event the thing gets crushed. dropped.. etc.. if you work at a sort facility and a bog with DG stickers starts to smoke you know to clear the area.... drop a box of flour an sugar.. bake a cake.
I'm only guessing but I bet the person most at risk (the truck drivers) are not properly trained to handle a DG problem in their trucks or at time of delivery.
Lessss said:FTFY: it's to protect the workers in the event the thing gets deliberately crushed by their reckless actions as they throw things around like footballs.
