lollandster
Hi, I recently bought a charger from greenbikekit.com That was suppose to be 48v. For some reason I ended up with a 24v charger instead (probably my fault since I was also ordered a 24v battery and a smaller 24v charger at the same time). Since it looks like the chargers are pretty much the same I was thinking it might be possible to convert the 24v charger into a 48v charger. The charger is marked 29.2Vdc and 12A, it needs to be 58.4vdc and 6A.
Is this possible?
I notice 3 pot meters. One is marked EMC-400 (it might be the board number and not the pot name though, the empty pot space beside it is marked VR4) and is 5k (502). Two others are 1k (102), one of those is marked VR3 and the other has its marking covered by white glue.
Is this possible?
