Onidaren
To start off, I have indeed read the wiki, some forum posts, build threads, etc. I have also done my own research independently, and come up with the following:
Ping batteries provide the maximum value in wh per dollar (48V, 30Ah pack produces a whopping 1.6 wh/$ !!!). If ping lives up to its ratings, it meets or beats everything including a123 after factoring in lifetime differences. Unfortunately, I can only take advantage of this if I have $1000 to spend. Which I do not.
I have $400 to spend on batteries for a starter electric bike. I have chosen this motor system:
http://www.leafbike.com/products/di...w-rear-hub-motor-bike-conversion-kit-613.html
All the reasoning behind my choice of motor system can be found here:
http://endless-sphere.com/forums/viewtopic.php?f=30&t=48202
I want to maximize efficiency. This means I can't be running a battery at its maximum rated continuous current - that would kill both capacity and lifespan. Can someone confirm that this is true?
The system is 48V, and I am fairly firm about that choice. That means the only ping battery in my price range is 48V and 10Ah. It may be found here:
http://www.pingbattery.com/servlet/the-48V-LiFePO4-Battery-Packs/Categories
Is it reasonable that I can run this battery at max for 3 minutes without damaging its lifespan? Should I opt for a less economical lithium polymer system in order to have a longer lifespan? After all, there's no point in spending hundreds of dollars on a battery and then toasting it within a month.
Here is a (polymer, I think) battery performance chart I found for a system that is running at a quarter of the power I will be using on a regular basis:
http://us.itselectric.ca/product_p/48v-lithium-polymer-10ah.htm
The battery appears to be roughly the capacity I am talking about. you can see that the temperature rises significantly for such a moderate load. If this is a polymer pack and it heats up so much, what would happen to a ping at four times that?? I'm guessing nothing good, but I may be wrong. That's what I want to find out.
