Victpower battery pack after 1 year
cwah   10 GW
Post by cwah » Jul 11 2013 8:30pm
Hello all,
I purchased the an A123 20AH pack from Victpower 1 year ago. And I was very happy at this time. But now my pack stopped working.
I looked at the pack and the box expanded:
So I dismanted the pack and realized one of the lead was disconnected:
Thanks Victpower for this poor soldering job....
And also one of the cell is swelling:
It completely pushed out the other cell:
Now I need to replace this cell. I have few problems to solve:
- Find a good supplier for new cell
- Any idea how I can test each cell individually without dismounting the pack? What's the best tool/way to do that?
- And to replace cell, I just need an iron?
Damn Victpower lol
ps: To view the pictures clearly, you have to zoom out from your browser.
knighty   10 kW
Re: Victpower battery pack after 1 year
Post by knighty » Jul 11 2013 8:38pm
you need to shrink the photos, even zoomed out all the way they still don't all fit
upload them to image shack (www.imageshack.com) and they'll give you forum links to post here, so we can see thumbnails, then click them to see bigger versions
how do you charge ? and do you have a bms ? - it's probably easier/better if you just remove that cell and run one cell less... but it depends on the rest of your setup if you can do that :-)
cwah   10 GW
Post by cwah » Jul 11 2013 8:42pm
The cells have all been soldered, so it's not easy to remove it:
I'm running them through a 20s BMS and charge with a 1000W charger. Should be fine as the cell are supposed to handle much much more.
I'm quite disappointed by A123 cells, I was expecting perfecting perfect things for many years.
circuit   100 kW
Post by circuit » Jul 12 2013 2:42am
black oxidation can be seen on the side. Usually this happens when there is a leak between any terminal and that cell's foil. So it could be a mechanical damage, rubbing etc. Or the foil got shorted to one of tabs during assembly.
smart and Tiny BMS solution
Visit my blog. Personal projects: Clean Peugeot conversion | Ultralight enduro
Any and all information, such as texts, specifications, drawings or other material that I post are to be used only as a reference for personal, non-commercial projects ONLY. Any republication for personal or commercial needs must be agreed on individually. Use of any information, that I post, for commercial purposes is strictly prohibited.
cwah   10 GW
Post by cwah » Jul 12 2013 6:33am
In which picture can you see black oxidation? Sorry my eyes are not expert at all
wb9k   10 kW
Post by wb9k » Jul 12 2013 8:08am
Wow. What a mess. Your cell surely got puffed up because the broken connection caused the BMS to overcharge or undercharge the cell. The black decrepitation seen on the puffed up cell also indicates, as others have mentioned, an internal leakage path for current between the anode (NOT the cathode) and the pouch. It may have overdischarged due to losses from that problem, then got hot on recharge as the dissolved Cu (from the anodes) in the cell plates onto the cathodes, forming dendrites that eventually puncture the separator and short the cell internally. This can make enough heat in the cell to break down the electrolyte and form gas.
Whatever the case, I have to say the problem here is not cells per se (though these were likely rejected by A123 for an actual reason before Victpower ever got hold of them), but the extremely amateurish design and construction techniques used to build the pack. No A123 cell is intended to have the tabs soldered--ever. That right there violates all kinds of handling and design rules. It appears there's no real mechanism for establishing or equalizing cell pressure, and many cells look bent and misshapen from the method used to bind them together. Why don't they run them through a blender while they're at it?
I understand your frustration, but to blame the problems here on the cells just isn't fair or reasonable.
dh
dh
2013 Chevy Volt
2009 Prius with Hymotion L5 PCM
2008 Prius with Hymotion L5 PCM (passed on to daughter)
2011 Rose Xing Fu 48V 500 Watt commuter scooter (now departed)
1984 Honda Interceptor 48V electric conversion motorcycle
Under construction: 2008 Miles ZX40ST truck with altered DC drivetrain
Departed: 2002 VW Jetta TDI which was run for a time partly on WVO.
Amateur radio station run entirely on solar/battery power.
"You can tell I'm a troublemaker, because I plug in my car."
cwah   10 GW
Post by cwah » Jul 12 2013 9:09am
I AM SO FRUSTRATEEEED.
How do I know which cell is still alive? I don't have any charger/balancer anymore :(
Do you mean the black mark on the damage cell means electrolyte leakage?
How should the pack be created then?
Lipo seem finally to be a better option
best
davec   1 kW
Post by davec » Jul 12 2013 9:26am
sure the pack was not built properly - if i recall a properly built amp20 module has cells standing up & also has the cells wrapped in a small casings with a compression belt .....also the tabs are professionally laser welded to bus bars- and the best of designs on here dont solder the tabs - but clamp
but regardless- it is the cells- i doubt it's the bms
i have been telling everyone on this forum for over a year that these grey sources are garbage
1. the CBA tests done confirm that they fall short on performance and 2. the cosmetic damage they come with is not pretty
im glad i got rid of mine before they puffed to death and going forward i will be buying legitimate even if i have to pay more
w9 being from a123 you should be aware of this link:
http://info.a123systems.com/contact-us- ... ing-cells/
cwah: if they start leaking get rid of it the msds on electrolyte is not pretty- with the puffed cells in this pack not sure how much of it can be salvaged
cwah   10 GW
Post by cwah » Jul 12 2013 9:40am
how can you buy legitimate cells if A123 are not selling them??? the pack was very expensive over 700USD and I don't want to throw it away???
and the pack was compressed firmly with tape so it wasn't supposed to move.
I'm so annoyed noww what should I do???
ambroseliao   100 kW
Post by ambroseliao » Jul 12 2013 9:56am
You could ask Cellman if he would sell some single pouches or take your chances on Fleabay...
http://www.ebay.com/sch/i.html?_odkw=A1 ... h&_sacat=0
http://www.ebikes.ca/ is the best!
TidalForce M-750X, Tidalforce S-750 with Crystalyte HS3540, 1x TF iO-X Cruiser. E+ 1000W hybrid bike. ebikes.ca DrainBrain & Cycle Analyst meters. GoPro HD Hero2 camera. Bosch Fat Packs, 37V 10Ah LiPO pack. Turnigy Multistar batteries
My blog: http://ebikerider.blogspot.com
Remember LiFEPo4 HVC is 3.65V and LVC is 2.7V
cwah   10 GW
Post by cwah » Jul 12 2013 10:15am
I was thinking to ask again Victpower as they have the best price and pack issues are related to the bad design?
or maybe OSN power for better cell quality?
dnmun   100 GW
Post by dnmun » Jul 12 2013 10:21am
no way to tell what you are talking about since the pictures are too large. why not take them down and set your camera mode to VGA and take a picture we can see?
ambroseliao   100 kW
Post by ambroseliao » Jul 12 2013 10:42am
I hope cwah doesn't mind! :oops:
Resized, levels adjusted and color corrected...
2013-07-11 22.00.05.jpg (214.33 KiB) Viewed 2887 times
2013-07-12 01.11.28.jpg (181.39 KiB) Viewed 2887 times
2013-07-12 01.00.41.jpg (219.31 KiB) Viewed 2887 times
2013-07-12 01.13.07.jpg (164.31 KiB) Viewed 2887 times
dnmun   100 GW
Post by dnmun » Jul 12 2013 10:58am
that one pouch has shorted to the aluminum layer in the mylar and eaten away the aluminum. is it possible the black stuff on the soldered tabs is rosin from the solder and it was never removed? that is how it looks when i cook something with the soldering iron and the rosin burns.
when i repair packs, i don't try to pull the tab outa the slot. i just melt the solder and stand the tab up vertically with one tip of the the two irons i use. then i cut the edge of the little pcb connector in line with the slot so the pcb can be separated at the slot and the cell removed. then just install the new cell there and make the connection by soldering a short piece of wire across the connection after the new cell is soldered in place.
docnjoj   100 GW
Post by docnjoj » Jul 12 2013 11:15am
I do remember when spacey showed a photo of this type of construction I was appalled then, about a year ago. OSN has a kit and Agnius has the best assembly package in the world. My 12S split pack is still doing fine even after a year of regualr use. It is from Victpower cells and Agnius kits 2x6S. All cells balance and no puffers. I got long tab cells when they were first being advertised so they may be of better quality. I did have to replace one cell but I had bought 2 extras. So far so good.
otherDoc
edit: Unless I know the next A123 pouch cells were top quality I would probably buy Headways for my next battery. Also easy to assemble and easy to replace bad ones.
E-bike stable at our house
Steintrike Mad Max full suspension trike rear Cute 100H going on: Whoops, Cute wheel broke but I fixed it.
Sun USX delta trike EbikeKit small geared front wheel sort of front suspension for wife
Agniusm/A123 AMP 20 36 volts on the Steini has been taken off.
2x16000 Multisport from HK now gone as they died after 2 years
New Luna 10S bottle battery 13.6AH now on mine
Relatively New 10S4Px2 for wife's bike giving 20ah @ 40 volts home made Panasonic from Tumich. BMS's rule.
davec   1 kW
Post by davec » Jul 12 2013 11:45am
cwah you're in the UK call up mavizen and see if they can help with a spare cell or two
personally i would not waste anymore more on this grey market crap- osn may sort them out better but they're still getting them from a dumpster just like everyone else is
put a voltmeter to each cell to see where they stand- also it looks like you will need to strip out the puff'd ones and solder a new one in---
cwah   10 GW
Post by cwah » Jul 12 2013 11:58am
docnjoj wrote:I do remember when spacey showed a photo of this type of construction I was appalled then, about a year ago. OSN has a kit and Agnius has the best assembly package in the world. My 12S split pack is still doing fine even after a year of regualr use. It is from Victpower cells and Agnius kits 2x6S. All cells balance and no puffers. I got long tab cells when they were first being advertised so they may be of better quality. I did have to replace one cell but I had bought 2 extras. So far so good.
otherDoc
Why agnisum kit is between than the one from OSN? The one from OSN looks simpler and doesn't need to drill any hole on the cells. Just plug and voila
Davec I'm not sure to buy from Mavizen are they are uber expensive and this pack is made of cheap A123 anyway
ps: Thanks for resizing my pictures
docnjoj   100 GW
Post by docnjoj » Jul 12 2013 1:35pm
otherDoc
It is easy to punch the holes with a paper punch hand held for agnius's kit.. I'm not so sure it matters unless we can find a reliable source of good A123 amp20 cells, cwah. It is too bad that they are going downhill now.
otherdoc
dnmun   100 GW
Post by dnmun » Jul 12 2013 1:42pm
unless you have the proper equipment, flux and skills it is impossible to solder the tabs back in there like i do with the ping packs. your only option is gonna be to hack the pack down in size and use the solder that is on the end of the old tab to make the connection across to the next pouch and just cut down the pack in series to 13S and hack the BMS to 13S to protect and balance it. it was 3 cells that are bad?
cwah   10 GW
Post by cwah » Jul 12 2013 1:48pm
otherdoc
I think I'm going to buy again from Victpower and do like everyone else:
Cycle them few times to check their capacity. It's almost 2 times cheaper than OSN. And probably something like 3 times cheaper than Mavizen.
I understand how to punch hole, but I don't see how it can be better than the one from OSN power that doesn't need any punching and is cheaper? What's the benefit over them?
cwah   10 GW
Post by cwah » Jul 12 2013 1:49pm
dnmun wrote:unless you have the proper equipment, flux and skills it is impossible to solder the tabs back in there like i do with the ping packs. your only option is gonna be to hack the pack down in size and use the solder that is on the end of the old tab to make the connection across to the next pouch and just cut down the pack in series to 13S and hack the BMS to 13S to protect and balance it. it was 3 cells that are bad?
I don't know how many are bad. I have to test them.
I'm still wondering where I can find good cells for battery? I'm thinking to get the 4s hardpack from Hobbyking they seem to be the most reliable and easy to change?
ambroseliao   100 kW
Post by ambroseliao » Jul 12 2013 1:59pm
I don't think Hobbyking sells the A123 pouches... I may have misunderstood you, cwah...
cwah   10 GW
Post by cwah » Jul 12 2013 2:24pm
ambroseliao wrote:I don't think Hobbyking sells the A123 pouches... I may have misunderstood you, cwah...
I mean stop using the A123 pouches and only use HK lipo as battery pack? Would be somehow simpler to fix and cheaper even if it only last 2 years
dnmun   100 GW
Post by dnmun » Jul 12 2013 2:54pm
why not just hack the battery down to 13S like i said? if you only have 3 bad cells then you could still make it work, maybe you would need a new BMS for 13S if you can't hack that one down. but you can adjust the charger down to 47.5V or so and then use it as a 13S pack. should still work.
cwah   10 GW
Post by cwah » Jul 12 2013 2:58pm
dnmun wrote:why not just hack the battery down to 13S like i said? if you only have 3 bad cells then you could still make it work, maybe you would need a new BMS for 13S if you can't hack that one down. but you can adjust the charger down to 47.5V or so and then use it as a 13S pack. should still work.
I don't want to loose power. It's a 20s battery and I sometime is thinking to hack it up to increase voltage and speed lol.
I'm thinking to get additional cells and the kit from OSN (unless anyone tell me how the one from Agnisum is better)
