Victpower battery pack after 1 year
cwah   10 GW
10 GW
Re: Victpower battery pack after 1 year
Post by cwah » Aug 05 2013 3:58pm
Thanks Agnisum. You don't like wood box? It was cheap and cost me nothing :lol:
I don't have precision tool to cut metal or epoxy, it's a bit annoying for me.
I'm not sure to understand what should be the size of the aluminium sheet? 700mmx1mmxthickness?? And how do I bend it twice?
Help me find my stolen electric brompton: http://bit.ly/1a0vbBC and Bosch Sinus B3 http://bit.ly/1eV0WQz
cwah   10 GW
10 GW
Post by cwah » Aug 05 2013 4:02pm
My battery is in bad shape, tried to charge it...
cwah   10 GW
10 GW
Post by cwah » Aug 05 2013 4:27pm
Here are the results while charging...
Looks like I have 2 weak cells... :(
agniusm   10 MW
Post by agniusm » Aug 05 2013 11:45pm
cwah wrote:Thanks Agnisum. You don't like wood box? It was cheap and cost me nothing :lol:
The size of aluminum would be 1mm thick by width of your cells plus compression plates and length which is 223mm x 2 sides plus the bottom.
You can make the drawing and take it to someone who has router to route it ;)
Wood is good insulator and not that fire resistant.
cwah   10 GW
10 GW
Post by cwah » Aug 09 2013 3:54pm
Thanks Agnisum but I'm trying to minimize the cost. I'm sure I'll get charged an arm to get aluminium+eposy sheet cut and routed. This pack is getting damn expensive and I'd like not to have a 50 euro box.
I have now a DIY cell voltage tracking :lol:
dnmun   100 GW
Post by dnmun » Aug 09 2013 5:07pm
so now you are at 16S of the original cells?
you need to protect the cells from over charging by using the BMS to charge.
you can try remove the resistor from the signal line for the next channel over and see if it works on 16S that way and if not you can buy another BMS to balance it and prevent it from overcharging any more.
cwah   10 GW
10 GW
Post by cwah » Aug 09 2013 5:57pm
I am now at 17s. I'm thinkinh to use my money to buy few spare cells to get 20S instead of a new BMS.
arkmundi   1 GW
1 GW
Post by arkmundi » Aug 09 2013 6:08pm
cwah wrote:I am now at 17s. I'm thinkinh to use my money to buy few spare cells to get 20S instead of a new BMS.
Not with Victpower, I hope. OSN? Or buya123batteries when they're back in stock?
cwah   10 GW
10 GW
Post by cwah » Aug 09 2013 6:20pm
Yeah maybe osn... Not sure yet
arkmundi   1 GW
1 GW
Post by arkmundi » Aug 10 2013 10:48am
cwah wrote:Yeah maybe osn... Not sure yet
You'll want to pay careful attention to this: http://endless-sphere.com/forums/viewto ... 50#p779451
ecross   1 kW
Post by ecross » Nov 04 2013 9:46am
NC 2805 mod.
H4080 mod.
4504 mod.
4503 mod. with watercooling
LiIon 24S16P from Sony, Sanyo, Panasonic
Siemens 2000W travel charger
Dlogic   1 kW
Post by Dlogic » Dec 21 2013 4:26pm
Hey Cwah,
just read through this entire thread. Sorry for all the trouble you´ve been through.
Although many members have had bad cells when ordering Hobby King Lipos, none of the packs that found it´s way into my bike had any problems when arriving here in Germany.
In roughly 2 years a total of 32 Turnigy nano tech 6s 8Ah packs came from China to my house. All the cells were balanced perfectly and had a storage charge of 3,85V.
The battery for my stealth custom built bike is made up of 12 turnigy packs. Having 4 in parallel and then 3 of these blocks in series gives me 32 Ah at 75V.
Prior to riding inserting a 42 pin custom " Harting " plug establishes all the serial connections combining the 3 blocks and thus producing an 18S 4P*4 battery.
The great thing is that when charging this using 3 i-chargers, they do all the balancing and checking. They even monitor the temperature. :-)
So yes, there´s no BMS. So what, i have 3 battery medics installed in the bikes dashboard and thus can see ever cells voltage at all times.
At around 3,6V i cut power and pedal home, if not there already. :mrgreen:
This is it. Machined out of aluminum this dashboard shows me every cells voltage. The round switch on the right side with the green wires cuts the power to the medics when the bike is not used.
So, i´ve done 214 cycles so far. Problems?
Yes, one cell dropped a bit more in voltage then the others on heavy acceleration.
Since this battery is modular it was easy to locate the problem. I could have just swapped that one cell soldering it out, but just sticking a new pack in there seemed safer and faster.
Believe it or not, this battery gave me 17481 km without any problems. The 109 $ spent on a new pack after all this time seems cheap.
Ok 1308 $ is what the whole pack cost me and it will probably die soon. My simple setup though gave me years of riding with no issues. Balance charging is essential. Prior to assembly all cells where charged individually to exactly 3,85 V.
izeman   100 GW
Post by izeman » Dec 22 2013 8:59am
could you PLEASE refrain from posting pictures in your signature? it makes reading experience much worse and noone else here does it.
thank you!
ps. super nice bike by the way :)
Dlogic   1 kW
Post by Dlogic » Dec 22 2013 3:26pm
Sure thing, just got rid of them. :mrgreen:
izeman   100 GW
Post by izeman » Dec 22 2013 3:28pm
Dlogic wrote:Sure thing, just got rid of them. :mrgreen:
999zip999   100 GW
Post by 999zip999 » Dec 22 2013 11:29pm
The OSN cells arn't looking to good these days. A123-20ah and Victpower is worst.
cwah   10 GW
10 GW
Post by cwah » Dec 23 2013 1:17am
Really? How are performing osn power pack? I've read only 1 negative review until now
