RC Lipo series charging tutorial
neptronix
Location: People's republic of Petrolistan ( Utah, USA )
Re: RC Lipo series charging tutorial
Post by neptronix » Mar 12, 2015 4:46 am
I wanted to give you guys a little update on what is going on with my lipo usage since i wrote this tutorial.
I still have a 10S pack. It is 4 years old with around 300 cycles on it and is still giving good capacity and staying in balance. Cherry picking the 20C 5AH packs out of 10 packs that i bought has worked out very well for me.
I made a big 12S pack from 15C Zippy lipo 2 years ago ( 30AH ). One of the packs had a slightly wonky cell in it. I left the battery discharged over the winter and the slightly wonky cell went bad, puffing up a little and leaking electrolyte. Lame! the other cells in the battery were down to about 2.9v on average. I took out the bad pack, slowly charged the rest of the packs 3.8 at 0.1A and made a 25AH pack out of what was left.
I hope to upgrade to the turnigy multistar packs in the near future. These 15-100C batteries are generally 150whrs/kg whereas the multistar are 190whrs/kg. I can fit 25ah into this triangle now, but with multistars, i can fit 30-40ah... that's rockin!
The same lipo advice i've given correlates with what you should do with Turnigy multistars. The discharge curve looks to be identical.
More threads by me on that topic:
Turnigy multistar VS. allcell comparison:
https://endless-sphere.com/forums/viewto ... 2&start=25
Maximum battery that can fit into a triangle bag:
https://endless-sphere.com/forums/viewto ... &p=1016496
My first major build: 8T MAC motor on a Trek 4500.
The new all-arounder: Leafmotor 1500w on a Turner O2 full suspension.
"The best time to plant a tree was 20 years ago. The second best time is now."- Chinese Proverb
longwise_suck
Post by longwise_suck » Mar 14, 2015 1:43 pm
thats a real nice bike is that a mac on the back wheel?
neptronix
Post by neptronix » Mar 14, 2015 2:22 pm
No. I no longer have a mac. I am running a leafmotor. ( read my signature for the build link )
Anveshsameer
Post by Anveshsameer » Apr 08, 2015 4:02 am
HI ya.... Last week I got stuff from HK and, last night I was charging the batteries.....
Here is the info
2x5s lipo
5000mah
I charger 1010b+
during my 1st charge I charged them upto 3.7v each
And next time when I left the charger to charge for 4.15 each, charger shows 4.2 v on each cell in the display and beeps indicating charging is completed.
When I check the voltage pack by a multimeter, it only shows 34 volts on total and 3.4v on each cell.
I had only discharged to 3.2volts on my first ride.
Any idea what's happening? I went through manual several times and also through forums, but couldn't find anything regarding the issue..
Help guys!
wesnewell
Post by wesnewell » Apr 08, 2015 8:04 am
Timer? Now edit your post and delete all the quoted part which is 99% of your post.
Anveshsameer
Post by Anveshsameer » Apr 08, 2015 9:23 am
wesnewell wrote:Timer? Now edit your post and delete all the quoted part which is 99% of your post.
what i actually see on the charger is
But, when i check the individual voltage of each cell, it is 3.1v i know it must be some changing in settings, that is what i was expecting from the readers ifthey had some experience with this JUNSI 1010B+ charger.
BTW sorry for quoting that long post,i wouldnt have drawn your attention if i hadnt done that! :p
Maybe i should read more about TIMER settings.
longwise_suck
Post by longwise_suck » Apr 08, 2015 9:42 am
Have you balance charged?
MrDude_1
Post by MrDude_1 » Apr 08, 2015 10:08 am
you probably are attempting a normal charge or a fast charge.
when you see that, you need to do a BALANCE charge.. or a discharge run.... so it can discharge the high cell and bring everything closer...
Warning:This post is being read via light, a substance known to the state of California to cause cancer.
longwise_suck
Post by longwise_suck » Apr 08, 2015 10:29 am
Those cells are new you need to balance charge them and cycle them a few times before they behave, I'm hoping you understand lipos?
Anveshsameer
Post by Anveshsameer » Apr 08, 2015 11:41 am
longwise_suck wrote:Have you balance charged?
yes, i balance charged them at 2 AMPS..
All i found on the charger during charging is
longwise_suck
Post by longwise_suck » Apr 08, 2015 11:45 am
I think you need to re-read this post some what carefully, you have one cell out of balance and it is at 4.2 volts ok what are the others at?
Anveshsameer
Post by Anveshsameer » Apr 08, 2015 12:57 pm
longwise_suck wrote:I think you need to re-read this post some what carefully, you have one cell out of balance and it is at 4.2 volts ok what are the others at?
BNBR longwise_suck...
I think you better re-read my question i had quoted at the start.I had some basic knowledge on lipos and well experienced with Formula student Electric from past 2 Years, and I'm not that dumb to leave a cell to get charged to 4.2V, I had quoted my problem saying that i had issues with wrong reading on the charger.
Now coming to the issue, there is no cell in the pack even charged to 3.2V !!
But the Charger shows around or greater than 4.1v on each cell.
MrDude_1
Post by MrDude_1 » Apr 08, 2015 1:13 pm
looks like your charger is screwed up. can you setup a power supply as a 1s setup, and test it?
dnmun
Post by dnmun » Apr 08, 2015 1:24 pm
the guy who posted the picture of the yellow voltmeter is measuring the full pack voltage of a 10S pack and not the individual cell voltages it appears.
but what is most obvious is that the battery is dead on his DVM so his measurements are totally useless.
Anveshsameer
Post by Anveshsameer » Apr 12, 2015 4:48 am
Ok...looks like i have overcharged one of my cell, but when i try to discharge my pack through the balancer, charger keeps on displaying "BALANCE PORT CELL HIGH VOL"
what should i do?
BShady
Post by BShady » Apr 15, 2015 11:06 pm
Got another qu!
Is it bad for the batteries to charge it in parts ( 1 hour increments) or should I charge the whole battery at one time (3 hours straight)?
longwise_suck
Post by longwise_suck » Jul 01, 2015 4:33 pm
i charge mine in one go, i have the same charger as you i use the temp sensor jammed in the middle of the pack and touch wood so far never had a problem, the problems with these chargers always seems to be when your discharging
geosped
Post by geosped » Jul 21, 2015 7:51 am
Advice needed: I'd like to make a 12S LiPo 10,000mah battery.
My charger has limitiations. I can only charge a 6S to 5,000mah
I'd like to utilize the two Turnigy Accucell-6 charger that I currently own. Should I just buy 4 6S 5000mah batteries and wire two of them up in Parallel then in series? OR
Is there an inexpensive charger from Hobby King or other that would charge up to a 12S 10,000mah battery? This would be better as I would have more options as opposed to sticking a bunch of batteries together.
Goal= 12S 1000mah 44-48v battery= 4 6S 5000mah 2 in parallel 2 in series correct??
Purpose= Offroad mountain biking hilly terrain. Tracks are no longer than 4-5 miles.
Novara Hard tail; BMC V2; 9 FET 72V Infineon Brushless Controller (LYEN's Edition); 12S 10mah Zippy Lipo Pack
longwise_suck
Post by longwise_suck » Jul 21, 2015 8:06 am
I use the charger above, it only charges 6s but at 10 amps an hour i use a balancing board to charge, the battery set up your are aiming for is exactly what I'm using on the flat running around the town just 25 - 30 kph i get almost 40 kilometres
DrInnovation
Post by DrInnovation » Jul 21, 2015 10:42 am
geosped wrote:Advice needed: I'd like to make a 12S LiPo 10,000mah battery.
Lipos need constant care and feeding to stay healthy.
The 12s packs I've seen (e.g. Spider have a break out for 2x6s balance leads.
Your charger should be able to charge two 6s in parallel, it will just take longer as it will only output 125 watts so it will take twice as long to charge the parallel pack.
If you are doing standard Lipo in 2S 2P 6S packs (which may be 2p or 3p in each 6S pack depending on manufacturer) you should balance charge the packs then connect their main power leads in parallel (e.g if using Deans T) then connect balance wires in parallel with something like this which will keep the 2p groups balanced while in use and also allow you to group charge them/check them. Then connect parallel power leads in series..
But for every day (I commute) I bulk charge my lipos with a modified Meanwell, and checked regularly with a celllog for blance and took it apart to charge the groups when needed. I also did not push the voltage, generally charging only to 4.05 average and only 4.2 when i knew I'd need more power. I did that for a year and just finally added a BMS so I don't ahve to keep taking it apart to balance charge.
Owner of a Crystalyte 4012/409 with 10aH 16s Headway on a old huffy frame. Its not fast but it climbs my daily commute up 8% and 10% grades nicely. Previous bike was a 24v Lashout 600w with RCLipos but I kept blowing the gears. I upgraded that one to a front-drive hub with a home-built 18650-based 20ah-36v. My bigger "E-ride" is a chevy volt.
amberwolf
Post by amberwolf » Jul 21, 2015 2:05 pm
geosped wrote:My charger has limitiations. I can only charge a 6S to 5,000mah
Already told ya how to fix that in one of your various threads. ;)
neptronix
Post by neptronix » Jul 21, 2015 2:23 pm
Cheap RC Balance chargers such as the ones that hobbyking rebrands and sells have a place - in the garbage can.
Get a name brand unit that receives good ratings and has a company that stands behind it. They will have more features than you know what to do with, and be so accurate that you'd need a very expensive multimeter to see any variation in how well they balance the cells.
When you are playing with the most dangerous battery chemistry you can buy, you do NOT want to cheap out on some charger that is not well built. Inaccuracy of many cheap balancing chargers makes a dangerous battery chemistry even more dangerous to handle.
http://hobbyking.com/hobbyking/store/__ ... arger.html
This is the cheapest charger that i can personally recommend buying - the entry level into the iCharger brand. They also have a 10S model.
http://www.progressiverc.com/chargers/b ... 1&top=684&
This is how much high end, well built chargers generally end up costing.
longwise_suck
Post by longwise_suck » Jul 27, 2015 12:53 pm
hello, does anyone have a clue why one of my packs jumps out of balance at every discharge? 3 are perfect but this one pack 2s2p will point blank refuse to stay balanced and it is never the same cells in the same small packs, it makes me want to pull my hair out, the other 3 are set up exactly the same and always run perfectly..im at a loss, any tips would be warmly received
MrDude_1
Post by MrDude_1 » Jul 27, 2015 1:49 pm
longwise_suck wrote:hello, does anyone have a clue why one of my packs jumps out of balance at every discharge? 3 are perfect but this one pack 2s2p will point blank refuse to stay balanced and it is never the same cells in the same small packs, it makes me want to pull my hair out, the other 3 are set up exactly the same and always run perfectly..im at a loss, any tips would be warmly received
there are only two reasons:
1. they see a different load/charge -- check all connections for starters. recheck circuit design. make sure nothing is pulling from one set without the others.
2. cells are going bad.
longwise_suck
Post by longwise_suck » Jul 27, 2015 2:11 pm
this is what drives me nuts its the same set up as all the others!! maybe somehow i got all the crap cells together in one pack
