Testing the lm431 shunt regulator
torqueon   1 kW
Post by torqueon » Aug 11 2013 7:53pm
I am trying to create a simple BMS just for balancing the pack, my cellogs will take care the rest, of the functions. So my 1st step, is to breadboard a unit to turn on at 3.6 battery volts, 2.5 reference volts.to light an LED, it works but the dead band is .5 volts from on to off seems to wide. Ive been under the impression that these can toggle off/on within .005 volts.
So the question is there a test circuit for the lm431, so I can eliminate the possibility that am frocking up L O L!
Thanks
bigmoose   100 MW
Re: Testing the lm431 shunt regulator
Post by bigmoose » Aug 12 2013 11:31am
Best to post your schematic. Something is a bit off.
"Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God..." all the best, Dave
dnmun   100 GW
Post by dnmun » Aug 12 2013 12:19pm
you can save yourself some effort by buying one of the older ping v1 signalabs BMS and reuse the 431 and voltage divider bridge on your circuit. or just use the ping BMS since it is cheaper than what you will pay for parts.
heathyoung   1 MW
Post by heathyoung » Aug 12 2013 7:44pm
Yep - post your schematic.
You must bias the TL431 properly or it will exhibit these symptoms.
www.onsemi.com/pub/Collateral/TND381-D.PDF‎
GNG offroad build on Craftworks DHR with 12S2P lipo. Light, balanced, powerful, able to climb a tree.
Project Vectrii (2) - status - Finished. Nope. 38S Leaf cells are next. Now have 2 of them - Averages 50Wh/Klm
torqueon   1 kW
Post by torqueon » Aug 12 2013 7:59pm
Thanks for the help. I am posting the schematic, mind you this is micro soft paint so bear with me. Hopefully all will under stand. Any recommendations on a better program for drawing schematics.
Yes I realize the economics of this project are poor, but I have the parts on hand. If anything it will be learning experience. I have a bad habit of pulling ideas of the web and running in to stone walls.
P S U.jpg (7.32 KiB) Viewed 1160 times
torqueon   1 kW
Post by torqueon » Aug 12 2013 8:41pm
After that PDF heath young posted, I am humbled, clearly way over my head!
Thanks for your time
Pete
bigmoose   100 MW
Post by bigmoose » Aug 12 2013 9:16pm
A journey starts with a single step, the one after another is added until one reaches their destination and is considered an expert in travel.
Don't be so hard on yourself, and don't give up! Start with the data sheet and ask your questions... no problem with a guy trying! :wink:
torqueon   1 kW
Post by torqueon » Aug 18 2013 6:56pm
Hey !!
Thanks again for the help. the circuit works a charm!! 0 amps to .75 amps, well within a 10 mv difference.
I never did get the LED to work directly off the LM 431. So I used a transistor to sense the shunt and drive the LED, nice and crisp turn on.
I am currently torturing the circuit, to be sure,
