Yet another Lipo Fire
lcyclist   10 W
Post by lcyclist » Sep 07 2013 8:42pm
While at out of the house today, my neighbor called me regarding a thick smoke coming from the front of my house. As I raced home,
3 fire trucks, a police car and the fire chief were in the front of my house. A good neighbor passing by had noticed the thick black smoke and called the fire department.
The fire came from my lipo powered scooter. I had just ridden it this morning, charged it and put in front of my house. The batteries were old and already puffed.
I have been meaning to replace it but had been lazy.
I was very lucky. The steel battery box contained the fire and protected my house. Exhaust vents and wire holes of the steel box prevented an explosion scenario.
No more lipo near the house for me. Be careful guys.
Here are some pictures of the carnage.
Battery box
cwah   10 GW
Re: Yet another Lipo Fire
Post by cwah » Sep 07 2013 9:45pm
Did you use a bms?
wb9k   10 kW
Post by wb9k » Sep 08 2013 12:05am
Any smoke damage to your home?
dh
2009 Prius with Hymotion L5 PCM
2008 Prius with Hymotion L5 PCM
2011 Rose Xing Fu 48V 500 Watt commuter scooter (now departed)
1984 Honda Interceptor 48V electric conversion motorcycle
Under construction: 2008 Miles ZX40ST truck with altered DC drivetrain
Departed: 2002 VW Jetta TDI which was run for a time partly on WVO.
Amateur radio station run entirely on solar/battery power.
"You can tell I'm a troublemaker, because I plug in my car."
dogman dan   100 GW
Post by dogman dan » Sep 08 2013 6:02am
Looks like perhaps mechanical damage was a possibility, but maybe whatever you had in there with them just burned away.
What exactly was underneath the packs like? I've gotten a lot of scuffing on the bottom of packs, unless they fit very very tightly in the enclosure. Looks like you had them at least taped up some for more abrasion resistance.
lcyclist   10 W
Post by lcyclist » Sep 08 2013 8:51am
wb9k wrote:Any smoke damage to your home?
I was fortunate it was at least 8 ft away from the walls. I did not see any smoke damage other than some soot on the walkway tiles. It cleaned up with no visible damage with water
and a little green scouring pad.
lcyclist   10 W
Post by lcyclist » Sep 08 2013 8:58am
dogman wrote:Looks like perhaps mechanical damage was a possibility, but maybe whatever you had in there with them just burned away.
Yes, Dogman. I had it taped up and the bottom/top of the steel enclosure has a rubber lining, but sides are bare steel. It was not a tight fit. Earlier that day, I had ridden it quite roughly and may have had the cells rub, causing a short to occur.
There will be no more lipo around the house for me. I am building a steel enclosure away from the house to store and charge them.
lcyclist   10 W
Post by lcyclist » Sep 08 2013 8:59am
cwah wrote:Did you use a bms?
No bms.
dnmun   100 GW
Post by dnmun » Sep 08 2013 9:03am
one of the main conductors has the appearance of having shorted and overheated. can you see that?
rather than just make a bigger steel box, you need to simplify the wiring to reduce the risk of shorts and then use a BMS to turn off the battery when it does short out.
cwah   10 GW
Post by cwah » Sep 08 2013 10:39am
No bms.
bulk charge lipo without bms is asking for fire. Another member had his house burned down because of this
Ykick   100 GW
Post by Ykick » Sep 08 2013 11:05am
OP mentioned puffing, eh? IME puffing can distort pouches enough to short tabs. I'm not saying that's what happened here but perhaps worth asking your local Fire Dept investigator for their expert opinion? They can tell a lot about how a fire started based on the visual condition of wires and/or metal contacts near source of ignition.
Glad you're alright and suffered only minimal property damage. Good luck....
- Frank Sinatra
TheBeastie   1 MW
Post by TheBeastie » Sep 08 2013 11:50am
I am not asking these questions to draw any conclusion just build knowledge database type thing...
What was the size of the battery pack? What brand lipo did you use? And what charger do you use?
Cheers!
Speed Kills Range, 10mph = 46 miles range, 20mph = 20 miles, 30mph = 8 miles rangehttps://goo.gl/1JNL53
Over Charging Kills ur battery bit.ly/1hzWKl4
Consider PAS as your only throttle https://goo.gl/Kg1F8F
Fuel-Cell is the ultimate battery coupled with 4th-gen Nuclear
https://goo.gl/TcKtHs https://goo.gl/ZhFFot https://goo.gl/gfa215
10 Square Miles of solar panels = 0.12GW average power! https://goo.gl/Ub1S39
silviasol   10 kW
Post by silviasol » Sep 08 2013 12:47pm
Wow, was there a charge for all the fire trucks coming to your house?
Current project: 10s 20ah sensored goped hoverboard
http://endless-sphere.com/forums/viewto ... 35&t=62155
riba2233   1 MW
Post by riba2233 » Sep 08 2013 12:55pm
silviasol wrote:Wow, was there a charge for all the fire trucks coming to your house?
Why would there be any charges?
We pay taxes, you know?
My electric moped: http://www.evalbum.com/4966
My electric car: http://www.evalbum.com/5364
athlon   100 mW
Post by athlon » Sep 08 2013 1:49pm
do you have the log of temperature and voltage of the sigle cells ?
I helps a lot to see what went wrong , sometimes it can be an internal short of the cell , sometime a localized overheating ..many thing can start a Lipo fire
Lipo are not 100% sure , are great batteries for power density and eneregy density , but greater power require greater responsability , the evil daemon of Lipo can emerge any time and only a loyal watchdog can save your house.
r3volved   100 kW
Post by r3volved » Sep 08 2013 5:18pm
Not sure what the regulations are for your area, but here they only charge you if there was no actual fire.
friendly1uk   10 MW
Post by friendly1uk » Sep 08 2013 6:06pm
cwah wrote:
No bms.
Not just one.
Fire some time after charging is not uncommon. Someone lost there garage earlier in the year this way.
There is no bms used in any of the fire threads I have seen.
It does not really look like there have been any flames. I wonder if you got a full burn or not. That could mean the remains are unstable.
Sorry to see your toy in such a mess.
I found a post listing the 5 likely causes of lipo fire, and an explanation of each on another forum: http://www.rctech.net/forum/electric-ro ... 101-a.html
A bms should sort out 3 of them. Hard case batteries a 4th. Leaving internal shorts out of our control. Nice metal box :)
bmsbattery sent me broken and incorrect stuff, and won't even talk to me about it.
chilledoutuk   100 W
Post by chilledoutuk » Sep 09 2013 5:12am
There have been plenty of fires with BMS protected battery packs!
Of course all lipo fires wont have BMS as nobody builds packs from lipo cells with BMS they are all hobby lipo's
Lastly Please do not brand all lipos with the same brush Cheap Chineese lipo packs are a Time bomb and need to be treated with care they are not designed to fail safe and have very poor quality control.
The wiring in there looks dreadful with cables going everywhere bouncing around in a metal box without any padding.
The problem with Hobby lipo is they are so powerful that if there is a wiring short you will certainly have a fire.
Putting a fuse inline on each pack would mitigate this problem from bad wiring.
Silicon wire is extremely flexible but has terrible cut resistance (Can easily strip with fingernail) and thus precautions need to be taken via different wire or thoughtful wire routing or both.
dogman dan   100 GW
Post by dogman dan » Sep 09 2013 6:11am
My opinion, this fire likely resulted from some form of physical damage, packs able to rattle around in there.
Or, did the padding or whatever just burn away?
Could have been a short in the wiring, or pouch damage.
I've seen two main culprits in the RC lipo "time bomb" fires. Shorted wiring, like a mistake when assembling. And physical damage to the packs.
friendly1uk   10 MW
Post by friendly1uk » Sep 09 2013 6:29am
chilledoutuk wrote:There have been plenty of fires with BMS protected battery packs!
I imagine so, but as a ratio of posts I have seen, the counter is still on zero. I have asked at least half a dozen times, but nobody has shown me a thread yet
This is not true. I'm sat looking at hobby lipo with a bms. Just because you buy from the cheapest outlet does not mean your cutting corners. Hobby packs always come with the correct bms wires hanging out of them, there is no reason to skip the safety device.
What lipo pack is not chinese and fails safe?
For you maybe, you don't use a bms. I had a short and no fire
Yes, with powerful batteries you need some sort of protection. On each pack would be great, but the balance wires are a problem. No need to call there delivery potential a problem though, It is certainly a bonus
Sleeving is the proper solution. Insulation is not mechanical protection
cwah   10 GW
Post by cwah » Sep 09 2013 6:40am
Do not forget all pouch cells need proper compression for good performance. Few members had A123 pouch cells without compression and they failed.
Proper compression to prevent cell to expand or any mechanical shocks, as well as a good BMS and you have a correct lipo pack.
dnmun   100 GW
Post by dnmun » Sep 09 2013 7:28am
dogman wrote:My opinion, this fire likely resulted from some form of physical damage, packs able to rattle around in there.
i could see that his main conductor had been shorted but he never replied. if he actually did some kind of analysis where he looked at the shorted wire and tracked down where it shorted then we would learn something.
chilledoutuk   100 W
Post by chilledoutuk » Sep 09 2013 10:09am
A BMS will only protect Some problems they will not protect from bad wiring and rats nests on the cell side of the pack.
18650 cells made by the big 5 can handle being shorted without exploding look at this data sheet for example.
http://www.batteryonestop.com/baotongus ... 50-26A.pdf
9. Safety
9.1 Overcharge Test
Test method: To charge the standard charged cell with 12V and 2.6A at 25℃
for 2.5 hours.
Criteria: No fire, and no explosion.
9.2 External Short-circuit Test
Test method: To short-circuit the standard charged cell by connecting positive and
negative terminal by less than 50mΩ wire for 3hours.
9.3 Reverse Charge Test
Test method: To charge the standard charged cell with charge current 2.6A
By –12V for 2.5 hours.
4
friendly1uk   10 MW
Post by friendly1uk » Sep 09 2013 10:51am
There very tame cells though. By 2c there down to 80% capacity. Max 4.25v so not really compliant with the average bms. Still, I'm surprised you found them.
It stands to reason that sluggish technology won't do a lot. I can't actually build my pack with them though, they are arguably different.
If you use these, and do short them, they could well burn up when they are charged again. Unless you have proper battery management they are little better. The fire could just happen another day.
nechaus   1 MW
Post by nechaus » Sep 09 2013 7:10pm
A BMS may only reduce the risk
How do we know this is simply not from a short?
The other big garage fire, i am not convinced it was not bc-168's fault, that charger seems buggy as hell
however this issue, I am interested in how it actually started.
dnmun   100 GW
Post by dnmun » Sep 09 2013 7:21pm
it was a short on his main conductor and you can see it in the photo. i hoped he would track down what it shorted to.
the reason a BMS would have prevented this is because when the conductor shorts the current surge will cut off the output mosfets and stop the flow of current.
