Military NATO lithium batteries
torqueon   1 kW
Post by torqueon » Sep 08 2013 9:40pm
Found these for sale $80 each
Does anybody here know anything about these batteries
Thank
Military NATO lithium batteries.jpg (28.84 KiB) Viewed 1033 times
DAND214   1 GW
1 GW
Location: About 1200 miles south of Chicago, in sunny/rainny Port Richey, Florida!
Re: Military NATO lithium batteries
Post by DAND214 » Sep 08 2013 10:58pm
torqueon wrote:Found these for sale $80 each
Thank
Where did you find it and does it have any specs?
Dan
torqueon   1 kW
Post by torqueon » Sep 08 2013 11:03pm
Craigslist, no specification. Looking at the connector I would assume its 5 series
liveforphysics   100 GW
Post by liveforphysics » Sep 09 2013 1:55am
Ive only seen one rechargeable lithium military radio battery myself, it was a box similar to those, and it was stuffed with tab welded 18650s.
t3sla   10 kW
Post by t3sla » Sep 09 2013 2:32am
wow thanks for that link, interesting read.
Include external safety components such as electrical fuses, blocking diodes against charging and Thermal Cut-Off devices to protect against overheating.
The main concern in Li-SO2 batteries is that SO2 gas, under abuse situations, can be released if the cell is venting.
Pull tab CDD (optional):
A device consisting of a manually activated pull tab and resistors designed to discharge the battery to 0 volts is built into the battery
Nice, I like fuse on each series block.
Endless Spirit.
Trilska   10 W
Post by Trilska » Sep 09 2013 4:50am
You cant believe the happiness when my platoon received a pre-series batch of li-ion to replace the lead for both the radio and manpad AA system, during my military service a couple of years ago.
Also the fact that we did not have to use primary batteries worth 200usd/night for the night-sight was quite comforting.
Join the dark side, we got cookies.
nechaus   1 MW
Post by nechaus » Sep 09 2013 7:17pm
Trilska wrote:You cant believe the happiness when my platoon received a pre-series batch of li-ion to replace the lead for both the radio and manpad AA system, during my military service a couple of years ago.
hahaha i can only imagine, what a upgrade !!!!
