Welding machine for Lipo Cells
Dlogic   1 kW
Post by Dlogic » Dec 13 2013 4:44pm
I´m planning on ordering a spot welding machine for soldering single lipo cells. Does anyone here have any experience with this, or know of a good spot welder?
This was found on ali-express. Don´t know if it´ll suit my needs?
http://www.aliexpress.com/item/POWER-78 ... 51068.html
agniusm   10 MW
Re: Welding machine for Lipo Cells
Post by agniusm » Dec 13 2013 5:16pm
Rodney64   1 MW
Post by Rodney64 » Dec 13 2013 7:32pm
Chris (Jonescg) made my pack they're made from single cells. He can sell you the boards for 20c and 40c cells.
http://endless-sphere.com/forums/viewto ... 75#p831084
jonescg   1.21 GW
1.21 GW
Post by jonescg » Dec 13 2013 7:37pm
You only need to spot-weld copper tabs to a cell if it only comes with an aluminium (+) terminal. Hobby LiPo always comes with two copper terminals, so soldering them is not a problem. Just make sure the iron is a big one - at least 80 W.
yuyuyak   1 mW
Post by yuyuyak » Dec 15 2013 1:00am
I'm building a Konion pack right now, but welding/soldering is a ways off.
I really like the welder shown here: http://www.avdweb.nl/tech-tips/spot-welder.html
I've got most of the parts already. In a couple of months I will have more to tell, if I'm not satisfied I will solder, but I'd rather not.
This is an interesting video of one of your countrymen soldering to Konions: http://www.youtube.com/watch?v=fKSV8T5wERo
He's on them QUITE a while with that iron, can't be more than 60 watts I think.
I'd be scared to heat them like that.
There are many opinions about spot welders here on ES, but the truth is there are a lot of variables in the process, which makes it difficult to sift through the advice. So I'm just going to try it and see for myself.
cwah   10 GW
Post by cwah » Dec 15 2013 6:00pm
agniusm wrote:
I purchased 2 model of these chinese spot welder, and they both failed. The first one on first usage, the second one after 1 week.
Worse thing is that aliexpress gave favour to the seller because I couldn't ship it back. So I have 2 non working spot welder at home :|
schwibsi   1 kW
Post by schwibsi » Dec 15 2013 6:20pm
You can't weld copper tape, unless you use electrodes made of wolfram, which you're not going to have. You're most likely to use copper electrodes.
Hilumin (nickel alloy) tape is choice, when it comes to welding battery cells.
Forget these chinese spot welders, they won't work.
You can also solder the cells, if the cells are not drift-free. But I wouldn't recommend it, as you're very likely to damage the cells.
You can build a spot welder yourself, but it's only worth doing, if you're making several packs. I wouldn't do it for just a few.
I built one, using 3s16p high power Li-Ion cells, an arduino for controls and 6 1324 mosfets to switch the power.
Works like a charm.
arkmundi   1 GW
1 GW
Post by arkmundi » Dec 15 2013 9:14pm
FYI, I'm currently experimenting with conductive epoxy as an alternative to welding or soldering. Too early to report my results, but if successful, it'll be less expensive and easier to do. I'll post a thread when I've got it down.
cwah   10 GW
Post by cwah » Dec 15 2013 9:20pm
arkmundi wrote:FYI, I'm currently experimenting with conductive epoxy as an alternative to welding or soldering. Too early to report my results, but if successful, it'll be less expensive and easier to do. I'll post a thread when I've got it down.
my guess is that conductive epoxy only works for low power applications/ebikes
arkmundi   1 GW
1 GW
Post by arkmundi » Dec 15 2013 9:35pm
cwah wrote:my guess is that conductive epoxy only works for low power applications/ebikes
Yea, just that, a guess, without any experimental data to work with. I'm doing that, and expect some failure before success. As with all such endeavors, if I did not have confidence in success, I wouldn't try it. But the cost of failure is also very low, so why not give it a try? I can always revert to soldering. There are good conductive epoxy's on the market these days and I'm giving several a try.
dnmun   100 GW
Post by dnmun » Dec 15 2013 9:41pm
if the spot welders are junk and fail on first use how is it that the guy in that video had no problems with his? maybe because he did not know the chinese were incompetent and the hundreds of billions of dollars of stuff they make for us is all that "cheap chinese junk" i read so much about from the bleachers here.
now who is it that makes all these hub motors, and controllers, and batteries, and and....
all those incompetent evil cheap chinese slave laborers. the 500 million people who have worked themselves into a middle class existence from desperate poverty, how many of those smart excellent Europeans made motors and batteries and controllers that anyone could afford? everybody wants a mercedes i am sure. yuk.
now we need to go war with them, they had the nerve to go land a rover on the moon. without passing our white man's competency test first. we need more nuclear carriers cruising off their coast to make sure they don't catch up with the western world, and we certainly don't want them spending all those dollars buying up oil companies and oil fields that are only for us to use first. shame on those cheap chinese for saving 50% of their income when they could be spending it all on more and more junk like we do.
arkmundi   1 GW
1 GW
Post by arkmundi » Dec 15 2013 10:11pm
dnmun wrote:all those incompetent evil cheap chinese slave laborers. the 500 million people who have worked themselves into a middle class existence from desperate poverty, how many of those smart excellent Europeans made motors and batteries and controllers that anyone could afford? everybody wants a mercedes i am sure. yuk.
The Chinese dragon has been awoken from its slumber, so watch out! We're all cattle in the open field now. Get this: China is graduating 35 times the number of students with advanced degrees than the USofA, by last count. And they are buying up every natural resource on the planet. They practially own Africa now. And what was their reason for going to the moon? You guessed it, geological exploration, looking for natural resources. They plan on having a permanent, settled moon base by 2030. They're in the process of "claiming" and unless the good ol' USofA gets up off its arse, we won't have an equal claim there. If you're under the age of 20, better start learning Chinese.
dnmun   100 GW
Post by dnmun » Dec 16 2013 4:17am
you do not have to learn chinese to interact with chinese engineers. they all speak clear fluent english. people in this country don't even study math, chemistry or physics. just video games and chase each other around with their iphone on facebook and tumbler. i think the most recent we have for a score in math is like #26, so why even worry about it?
we have now tapped the source rock and are using up the natural gas and crude as fast as we can produce it and then when it is gone we can try to buy it from someone else. but there is never gonna be a productive basis for the creation of the means to purchase it then. schools in this country are a joke. it really is a shame. we have the power and insight to see how the world is gonna end up because of the global warming and sea level rise but cannot change it because the greed of everyone here who think they are entitled to use as much energy as they can, since this is a FREE country. just selfish greed. me first forever, the american maxim. kill'em all and take the oil is our approach to the arab world that provides it.
arkmundi   1 GW
1 GW
Post by arkmundi » Dec 16 2013 4:35am
Amen brother! Hallelujah brokers of a pointless future.
agniusm   10 MW
Post by agniusm » Dec 18 2013 2:37pm
This thread went balls as so many here on ES. Pointless arguing over nothing. Anyway, i'd like to thank yuyuyak for sharing arduino diy spot welder. I went to a disposal place and picked up transformer of an old 1450W microwave. I had some heavy duty copper wire from an old forklift that i salvaged some time ago. At the moment i have almost done electrodes and mechanics. I would like to install some kind of independent electromagnet to pull equally on each electrode against the cell surface. Attempt on 4mm nickel strip vaporized it, so there is adequate power, timer will solve the rest.
yuyuyak wrote:I'm building a Konion pack right now, but welding/soldering is a ways off.
grindz145   100 MW
Post by grindz145 » Dec 18 2013 2:47pm
120 bucks for that welder is a steal. I bought a similar unit for 300 bucks and it's serving me well. I was using a transformer, but then I just threw a dryer outlet 220 connector (in order to get 220 single phase in the US) and it worked fairly well. Not commercial grade, but not bad for hobbyists.
Dlogic   1 kW
Post by Dlogic » Dec 30 2013 1:48pm
Ok, this machine is a bit more expensive, but it seems to be worth the money.
We´re talking about 1400 € for the bundle.
1. Welding Transformer
2. Adjustable electrode holder.
Check out the video
Next year i will visit the guy that manufactures this machine. If it performs as stated, it will be another tool in my workshop soon.
My bike will then get a custom welded pack out of these cells.
----Sony Konion (US18650VTC4)----
:mrgreen:
knighty   10 kW
Post by knighty » Dec 30 2013 2:34pm
I'm a bit late here
but someone on here bought one of those cheap tab welders (on ebay iirc) and it was junk...
I don't care where it's made from, you get what you pay for
(unless you build it yourself)
docnjoj   100 GW
Post by docnjoj » Dec 30 2013 3:17pm
I don't know, knighty, but spending $1800 or so doesn't seem cheap. The video seems to show high quality. I have seen cheap welders for $100 on ebay, but this one looks worth it. Not that I am going to get one soon. :mrgreen:
otherDoc
E-bike stable at our house
Steintrike Mad Max full suspension trike rear Cute 100H going on: Whoops, Cute wheel broke but I fixed it.
Sun USX delta trike EbikeKit small geared front wheel sort of front suspension for wife
Agniusm/A123 AMP 20 36 volts on the Steini has been taken off.
2x16000 Multisport from HK now gone as they died after 2 years
New Luna 10S bottle battery 13.6AH now on mine
Relatively New 10S4Px2 for wife's bike giving 20ah @ 40 volts home made Panasonic from Tumich. BMS's rule.
liveforphysics   100 GW
Post by liveforphysics » Dec 30 2013 3:46pm
In industry, ultrasonic welders are used for joining pouch cell tabs most commonly, with relatively slow-ish resistive heating welding being sometimes used in conjunction with ultrasonic welding. A123 used a special powder metal laser welding method which had relatively high fall-out (there is good reason that's not the industry standard method).
As far as welding highly conductive foils with a capacitive discharge welder reliably, good luck. The current densities needed to flash copper foils to molten typically will also have such strong magnetic fields the molten material splatters from localized magnetic repulsion. At least that's how my experiences with it went, if you turn the energy dump up enough to really melt the metal, it splatters, if you decrease the energy, it just makes a joint that visually looks like a weld, but you can knock the weld apart with a brush of your pinky.
My favorite method for joining foils is mechanically crimping. When done right, ultra-low resistance, excellent mechanical strength, and the lack of heat/arcing involved make for good quick easy joints that don't require special equipment beyond a crimper for under-floor heating foil connections.
docnjoj   100 GW
Post by docnjoj » Dec 30 2013 5:15pm
Interesting LFP. that is why oatnets and agnius's clamps seem to work well. Thanks.
otherDoc
edit: Actually oatnet did use a cheap HF crimp welder with cotterpins for his A123 pouches. It think dlogic is trying to just weld nickel tabs onto the little cylinder 18650 cells?
999zip999   100 GW
Post by 999zip999 » Dec 30 2013 6:17pm
I still would have them welder in parelle from the seller and series them myself with a 80 watt iron. Yes like spiningmagnets did.
parabellum   10 MW
Post by parabellum » Jan 07 2014 10:59am
Maybe a good candidate to rip open and modify it, nice enclosure for that money. :D
Spacey   100 kW
Post by Spacey » Jan 07 2014 4:07pm
All the Positive connections on my A123 36v Packs from Victpower had stupidly been soldered. They all came off by just touching them, my solution was to drill 6 holes big enough to pass 14Awg copper rc cable through and wind it through the tab as much as I could. I would then crimp the foil tab and carefully solder lead easy flow solder through the copper cable.
Worked really well, I never put more than 20A through these packs so it will be more than sufficient for that. I can not believe they honestly tried to solder copper cable to aluminium foil doh!!!
http://www.custom-ebikes.com is my new Ebike company serving the Uk and Europe
Free Uk shipping over £49.99
agniusm   10 MW
Post by agniusm » Jan 08 2014 2:39pm
Dont know about you guys but i like this machine:
