Charging nimh battery
silviasol   10 kW
Post by silviasol » Dec 25 2013 9:28am
I have this 14.4v 360mah battery meant for a small printer. It is completely dead and the printer won't charge it for some reason so I wanted to put a small charge on it then try again. I went to charge it on my b6ac and the voltage went up to 26v so I shut it off. Is this normal?
Current project: 10s 20ah sensored goped hoverboard
http://endless-sphere.com/forums/viewto ... 35&t=62155
Ypedal   100 GW
Re: Charging nimh battery
Post by Ypedal » Dec 25 2013 9:38am
instead of " auto " set it to the proper number of cells ( 12 ? ) and 0.2 amps...try again.. but it's likely toast...
ES site status page:
deardancer3   10 kW
Post by deardancer3 » Dec 25 2013 9:47am
did it overheat when charging to 26v?
if no, then you have an open circuit somewhere you should resolve.
if yes, then it is toast.
dick
Chain Drive Advocate
silviasol   10 kW
Post by silviasol » Dec 25 2013 9:58am
It didn't overheat. I just let it charge since the cells did not get hot. I noticed the voltage variate from 26v to 17v. The charger said it was fully charged within a few minutes. It had 17v but was draining on it's own fast.
I couldn't find any option to change the number of cells in the menu.
