BC 168 balance charger
space4dreamz   1 W
1 W
Post by space4dreamz » Jan 07 2014 4:50am
Does anyone knows where can I find a user manual for that charger?
I've lost mine and I can't find it anywhere on the net.
Thanks guys
Spacey   100 kW
Re: BC 168 balance charger
Post by Spacey » Jan 07 2014 6:21am
Took me 2 seconds :)
Google is your friend, not sure they deliver to the Milky Way though.
http://dx.com/p/bc168-1-6s-8000ma-200w- ... ger-124483
http://www.custom-ebikes.com is my new Ebike company serving the Uk and Europe
Free Uk shipping over £49.99
space4dreamz   1 W
1 W
Post by space4dreamz » Jan 07 2014 6:35am
Spacey wrote:Took me 2 seconds :)
Big Thanks! but I can't see the user manual there. can you?
Spacey   100 kW
Post by Spacey » Jan 07 2014 5:15pm
Damn my Dyslexia! I thought you were looking for the charger to buy.....I do apologise.
I have one of these units, can't find the manual myself...anything I can help you with?
agniusm   10 MW
Post by agniusm » Jan 07 2014 6:01pm
I think there is none. They printed all the manual all over the charger itself :D
space4dreamz   1 W
1 W
Post by space4dreamz » Jan 07 2014 8:40pm
Thanks guys.
What I couldn't understand was the 5 beeps it made occasionally while charging/balancing.
Finally I realized that the bc168 can't get enough current from the psu. I've lowered the current and the beeps stopped.
All welll now.
pendragon8000   1 MW
Post by pendragon8000 » Jan 07 2014 8:58pm
What is your low voltage alarm set at?
I have run mine at 11 v but the charger acts weird, uneven power to the channels.
If you get a decent PSU you won't regret it.
Mean well 350watt or a copy/ clone
8)HYENA high power ebike kits
My builds
scott 29er + Hyena kit, mon-goose to MON-STER 6KW, Free Agent RC Mid Drive, videos
my bike goes so fast 'cos it charges the battery while I pedal
space4dreamz   1 W
1 W
Post by space4dreamz » Jan 08 2014 8:30am
pendragon8000 wrote:What is your low voltage alarm set at?
I'm using a simple 12V/4A PSU till i'll get a decent one. The current one is allowing 1.3A per cell which is ok cause i'm using it only for balancing after bulk charging (The HVC stops the bulk charge when one cell reaches 4.2V).
The low voltage alarm is set to 11.9 (The PSU out is 12-12.5V). Since I lowered The current to 1.3A - no problems.
BTW, did your son really found Excalibur?
space4dreamz   1 W
1 W
Post by space4dreamz » Jan 11 2014 4:37am
Does somebody understands what does the values 05-30 mean?
I can't spot the difference when I'm changing that value.
Thanks guys.
major   10 kW
Post by major » Jan 11 2014 6:49am
space4dreamz wrote:Does somebody understands what does the values 05-30 mean?
Instruction book; page 6; para h.
Under charge trickle frequency set up mode, push _ or _ to adjust the trickle speed. After that and then push MODE to enter change time set up mode. (Set scope: 5 ~ 30, Pre-set 30)
Is that what you are talking about? I am confused about it also. Two manuals were included with my BC168. One is in Chinese and is of no use to me. The other is a little better.
pendragon8000   1 MW
Post by pendragon8000 » Jan 11 2014 9:00am
frock the manul you need a good PSU. then life will be good
My builds
cybercrash   1 mW
Post by cybercrash » Feb 09 2014 11:03am
I am looking for a manual for the BC168.
Who knows a link? Or would take some pictures?
I would like to compare this charger to this one: http://radiolink.com.cn/doce/UploadFile ... 490313.pdf
Thanks
mushymelon   1 kW
Post by mushymelon » Feb 09 2014 2:20pm
Thanks guys.
This is the delay in seconds when it puts juice into the battery during the final stage of balancing. With 05 setting you will notice more action topping up the batteries at the end in shorter intervals. 30 will have less action with longer run times. 05 will balance faster 30 slower but only by a minute or two.
i think when it reaches its final voltage lets say 4.2 when the voltage drifts down to whatever the threshold is 4.195 or whatever then there is a delay in when the charger kicks in.
I set all 4 chargers to 05.
Mushy
cybercrash   1 mW
Post by cybercrash » Feb 09 2014 5:36pm
What other functions does this charger offer?
Scottydog   100 W
Post by Scottydog » May 28 2016 7:53am
Just looking at this charger, can you charge 6 cells connected in series with balance boards in place? I'm just wondering how it works with the series connections?
jordison   10 mW
Post by jordison » Mar 02 2018 3:15pm
the cells are all 3.77v and it shows like the picture, doesn't read some cells and the others are reading wrong values.
the input voltage was 15.2v, was that to much?
nothing smells or looks burnt.
